Modding 1st Dremel Mod... What Should I DO?
Discussion in 'Modding' started by NoObY-DoObY, 24 May 2003.
  1. NoObY-DoObY
    NoObY-DoObY Hanging on by a thread...
    29 Apr 2003
    im dumb so i dont understand y i cant make a new thread in the article discussion thingy aand i looked for the article but in where the guy makes an ephia pc case he strips his dremel jhow u dothat?
  2. linear
    linear Minimodder
    5 Oct 2001
    The article discussion forum is configured so that only staff can start threads--we start one for each article, around the time the article gets published.
    If you want to find the discussion thread for any given article, go find the article first, then thee will be a "discuss in forums" link at the right with all the other navigation links.
  3. Spyder
    Spyder What's a Dremel?
    30 May 2003
    Im sure there are some very good tutorials here at Bit-Tech but the first place that comes to mind ishttp://www.mnpctech.com/Dremel2.html
    Something I did to make cutting easier when I first started to use a dremel was to pre drill holes with a drill and then cut my design was more or less a starting point or connect the dots. Keep in mind most of us that use dremels go though many cutting discs. Dremel is also makes a re-enforced cutting disc that I have not tried yet but looks like could last longer. Just some thoughts. Hope it works out for you and dont give up!
  4. NoObY-DoObY
    29 Apr 2003
    thnx spyder and hi welcum to the forums but someone already told me that... thnx though
  5. Morphine
    Morphine weeee!
    23 Feb 2002
    /off topis, n00by your never on AIM/MSN
  6. BasicBubbleHJK
    BasicBubbleHJK What's a Dremel?
    4 Feb 2003
    i was thinkin of removing the grilles from in front of my case fans as my first real dremel mod. Was wondering if everyone empties all the gear out of their case before doing this sort of thing, or can you just mask off the back?
    How long does it take to remove all the hardware from a case?
  7. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    I took out the stuff inside when cutting.. hat fine metal dusk can do some serious damage! :eeek:
