Case Mod - In Progress 1st ... KONTAKT by SpikeV
Discussion in 'Project Logs' started by SpikeV, 13 Feb 2020.
  1. Canardwc
    Canardwc @French_fab_factorie
    22 Sep 2011
    Love the catamaran boat !
  2. SpikeV
    SpikeV Minimodder
    11 Aug 2018
    Yeah, was, and is, a beauty (Choydesign / C/S/K Catamarans) ... definitely miss those days - the best job on earth !!! :grin:
  3. SpikeV
    SpikeV Minimodder
    11 Aug 2018
    Well, the project has slowed a bit . . . working on getting the four distribution panels into 3D vector format and arrange for CNC time.
    So, have been making arrangements for many of the fabrication tasks - and there's a bunch . . . looking at Vector file work, CNC & bit selection plan, Laser tasks, Vinyl cutter, 3D printer ... sourcing Hydrographic materials, and of course, getting ready for serious cable sleeving - all of these depending on each other for proper sizing :idea: . . . and once these are mostly done, can then move on to tube alignment, fabrication & bending ... :thumb:
    Meanwhile, working some of the little tasks of acquiring miscellaneous parts and readying some details to realize the vision. :naughty:
    Here is just one . . .
    While I am super happy to be working with the Cougar Conquer case, the Cougar branding on the glass side panels seems a bit over-the-top - so need to mute this just a bit ...
    Not sure how this has been applied
    Originally thought it was just printed or silkscreened on ... but it seems that it is something else - looks like some sort of heat or chemical transfer. So I am scraping the white material off of the inside application. This generally works - but leaves an opaque impression on the glass (doesn't seem to be adhesive, but rather some resulting etching)
    so, with an opaque background, the logo disappears . . . but, yet to be seen exactly how it will present in the end - muted for sure though!
    :rock:
  4. SpikeV
    SpikeV Minimodder
    11 Aug 2018
    ... been working on the details for the four acrylic panels - 2 Reservoirs and 2 Distribution
    Since each needs to be specifically placed and ports need to be dead-on in order to hit plan, as they say ... the Devil is in the Detail :eyebrow:
    Fortunately, I have the support of a good friend - Søren Kirkegaard of Nordic 3D design https://www.facebook.com/Nordic3Ddesign/ and the CAD files are coming together. Way more details going into these critters then may be initially apparent due to each piece requiring unique 3D positioning, exacting fitting placement, some unique etching, and requirements for edge lighting. So plenty of challenges to be solved (and, of course, that's where the real fun is :thumb:)
    Whee-ew! ... that was easy !!! o_O :)
    Cheapskate likes this.
  5. SpikeV
    SpikeV Minimodder
    11 Aug 2018
    ... validating the CAD files
    . . . boo-yah :thumb:
  6. SpikeV
    SpikeV Minimodder
    11 Aug 2018
    ... a bit of a diversion in order to begin to get ready for some cabling work
    as usual, will be trying something a bit different
    (custom cables are totally cool - but for my projects, not a big fan of the typical Big Ol' Flat 16AWG, cable combed effort that rarely ends up with good alignment [weird twists and angulation] ;) . . . so, let's see :rolleyes:)
  7. SpikeV
    SpikeV Minimodder
    11 Aug 2018
    Holy Crap !!! . . . can there be any truth in this chatter?
    Is anyone else aware of a Flame-out issue with Corsair Node Pro controllers? . . . just today running into net discussion about the scope of this potentially 'smoking-hot' problem :oldconfused:
    Inquiring minds need to know :eeek:
  8. Cheapskate
    13 May 2007
    6 (or more) high -draw fans on a single 18awg wire? Sounds believable to me.
    You could potentially be pulling 8+ amps through it at full speed.
  9. SpikeV
    SpikeV Minimodder
    11 Aug 2018
    As I understand it (and I am engineering impaired!) max throughput for a SATA connector is 4.5 amps ... but this thing is only driving LEDs (fan spin is handled otherwise)???
    [BTW, I was happy to get smarter after always wondering - why the pump people never config'd with SATA connectors rather that big Molex 4-pin]
  10. SpikeV
    SpikeV Minimodder
    11 Aug 2018
    ... teaser time - another little side task coming up :idea:
    Candy-apple RED (quick pic doesn't do it justice ... Suu-weet!!!)
    ... a bit of clean-up, and the first batch is done ;)
    Cheapskate, ivory2k19 and idpcmods like this.
  11. 4LIEN
    4LIEN Minimodder
    4 Jan 2020
    Very cool work with that reservoirs!
  12. SpikeV
    SpikeV Minimodder
    11 Aug 2018
    Thanks 4L ... working through lots of little details for production - taking a bit more time than hoped ... but still progress :thumb:
  13. SpikeV
    SpikeV Minimodder
    11 Aug 2018
    Fans are done.
    decided to do the full set ... a sparkling * result ! :thumb:
    ... candyapple red with pearl clearcoat
    :clap:
    idpcmods, Cheapskate and Flux like this.
