Planning 1st Mod Black Mesh - Design & ideas planning
Discussion in 'Modding' started by Genghis, 11 Apr 2011.
  1. Genghis
    Genghis What's a Dremel?
    8 Apr 2011
    Hi there,
    i'm a rookie in modding. but i have some ideas, a little bit of brain in my head :thumb: and lot of motivation to make a great MOD.
    My first inspiration is the Level 10 case from thermaltake. i love the concept but to cold in design.
    My mod will be based on level 10 concept... so all component separately, minimum wire view, watercooled.
    So i start the design in 3D with cinema 4D software.
    base is two vertical plexiglas plate for support the hardware, i tought about one 20mm plate and 10 or 15mm plate for the right side. and a base plate for the stability.
    the PSU will change orientation to make the wire management more easy, the PSU wires will be between the two plexi plates.
    The stockage is on the base in two (or three :rolleyes: ) Scythe Himuro case with the sleeve behind.
    More image later with the hardware in place
  2. danitgeek
    danitgeek Designer
    17 Sep 2010
    I was just wondering where did you get the mesh metrial for cinema 4d?
    I like desgin the "backplate" is more rounded them the level 10 which makes look smooth and great
    i will look forward to see how it comes out ;D
  3. Genghis
    8 Apr 2011
    The material is part of engineering module for cinema 4D.
  4. Genghis
    8 Apr 2011
    Evolution of design.
    This design requires the use of a riser for PCI video card.
  5. Genghis
    8 Apr 2011
    I must find a way to put water container and tubing.
  6. danitgeek
    danitgeek Designer
    17 Sep 2010
    look much better :D
  7. cchr
    cchr Minimodder
    24 Nov 2010
    this is a fantastic design mate, where do you plan on placing your PSU?
  8. Genghis
    8 Apr 2011
    the PSU will be place here between the two vertical sheet
    like this it simplify my cable management
  9. StonieX
    StonieX What's a Dremel?
    23 Dec 2003
    the design is really awsome! I love it! I hope there is really enough place for all components :).
  10. Genghis
    8 Apr 2011
    In principle, yes, everything must go. I'll just be bothered with the video card and PCI riser but it should go. for the moment I thought about the integration of the reservoir / pump (the pump is down) and the choice of radiators. The original idea was to cape cora with 6x120mm fans but I do not know if it's going to go for watercooling CPU / GPU
  11. Genghis
    8 Apr 2011
    new integration of water container and pump.
    combination pump + top plexi with container EK 140
    and the DVD driver move under the HDD.
    cable management more clean and easy :)
  12. cchr
    cchr Minimodder
    24 Nov 2010
    i know that what i'm about to say might sound a bit weird as an idea, but i'm gonna go ahead and say it.
    those 4 stands that you have for the HDDs could be replaced by 4 small reservoirs in the same shape.
    this means that there would have to be a way for these reservoirs to communicate so the fluid can run from all 4 of them. i dont know what implications that may have in implementation (need for more pumps) as i do not have a lot of experience with watercooling.
    again, i love the design!
    cheers,
    chris
  13. Genghis
    8 Apr 2011
    in fact, the four stands are full plexi, not tube.
    and make them begining reservoirs is too much work on small pieces.
    on the design, the stands are 20mm diameter... so too smal to begin reservoirs i think.
    so it's a good idea, but i will have too much tubing to place and i think it will be disgrace with the design.
    i will thinking at the most difficult part of the MOD, make the tubing without disgrace.
    thanks for following :)
  14. cchr
    cchr Minimodder
    24 Nov 2010
    Yeah, that's what i figured.
    just thought i'd lay it on the table:D
    cheers
  15. Genghis
    8 Apr 2011
    in fact this is a great idea but the reservoirs must be hand made pieces, i doubt i can find on the web a four in one reservoir :thumb:
    but... maybe for another build... who know :dremel:
  16. lucasrubini
    lucasrubini What's a Dremel?
    26 Feb 2011
    The design is beautiful Genghis, i really loved it! What would be the dimensions of this case?
  17. Genghis
    8 Apr 2011
    the vertical sheet mesures
    600mm depth
    700mm height
    400mm width
    a vue right side
    i'm not sure yet for the rads, i've selected cape cora for the design but i'm note sure they be enough performant for i7 2600k and CG cooling
  18. NavidsonRecord
    NavidsonRecord Where the bloody hell are ya'?
    5 Jan 2010
    looks great. I wouldnt say its a lv10 copy at all... much more stylish and well planed :)
  19. Genghis
    8 Apr 2011
    the level 10 is the "muse" :)
    but i want to make something ... different, coldless, more smooth ;)
    i've even try integration with two 360 rad with fans for test, it works but the six fans will make noise at all. and what i want, it's a noisless Mod. that what i selected the alphacool Cora 642
  20. Genghis
    8 Apr 2011
    hi guys, one question about the watercooling planning.
    i would take a alphacool cape cora 642 for the silence and design.
    i plan to watercolling the CPU and the GPU (maybe a GTX 560 Ti)
    if i place 6 120mm fans betwenn the two vertical sheets to push the warm air from the rads... it is enough?
    or i must take conventionnal rad like two 360?
