Does anyone know where I can get hold of a 1U heatsink that supports upto XP2600+ Bartons? I know the Akasa, but it is stated only upto XP2000+. Any help would be greatly appreciated. Cheers,
kustom pcs, tekheads and another major online retailor (ebueyer/micro direct- not sure on this) but kustom pcs have 3 types
A13: Server will be rackmounted, so noise isn't an issue. JRY: Thanks for the links - but the Akasa 350 is only upto 2000+, seems that i'll just have to try and risk it. :/ Cheers,
it should work fine. just make sure there is good airflow around the cpu socket persoanlly i would get a cheap copper non-1u hsf and just chop it down to size
Looks like there's only one that will do it.. and you can't buy it in the UK,.... http://www.rackmount.com/Rackacc/CPU-P3-B1.htm
theoverclockingstore.co.uk used to do an Alpha 1u heatsink which was quite good, shame they closed down, not sure on the model either, it'll prolly tell u on the alpha webby
