Networks 2* 360's on Network
Discussion in 'Hardware' started by samkiller42, 28 May 2013.
  1. samkiller42
    25 Apr 2006
    Hi All,
    Got a small problem that's been bugging me for a few months now.
    Got 2 Xbox 360's on the Network, and if i'm signed in, all is well, If the other is turned on, then i'm disconnected, and can either take an age to re-sign in, or just flat out refuses too.
    So:
    360 A is connected to a Switch, which is then direct into the Router (Draytek 2850n)
    360 B is connected direct to the router via a Ethernet over Powerline
    Both 360's where assigned IP's, but i've bound them by MAC, so the IP's never change from 192.168.1.17 and 192.168.1.19.
    UPnP is Enabled, and i've also opened up all ports, and linked those to the 2 IP's, yet the problems still persist.
    Any idea's on what i should do. Looking around various sites with the same issue seem to give mixed fixes.
    Many thanks for any ideas.
    Sam
  2. longweight
    7 May 2011
    Are you using two different xbox accounts?
  3. samkiller42
    25 Apr 2006
    Yes, Gamertags are only on our own consoles.
    Sam
  4. Big_malc
    Big_malc Minimodder
    7 Sep 2010
    try moving the I.P range further appart
  5. Jaybles
    Jaybles What's a Dremel?
    12 Feb 2011
    Not sure how that would help o_O? But give it a try I don't know everything :).
    Anyway what happens when you run them in a DMZ?
  6. jinq-sea
    15 Oct 2012
    I'd give that a pop.
  7. samkiller42
    25 Apr 2006
    I've moved my 360 onto a new IP of 192.168.1.30, working ok for now, but no one else on the network. I've read that sticking a 360 into a DMZ does work, but mixed results, i've also read that Port Triggering fixes the issue. Will give the DMZ a shot, See if that works.
    Cheers,
    Sam
  8. samkiller42
    25 Apr 2006
    Well, Something isn't happy, got kicked off Live with no one on the network, nobody else in the house, so not sure what's going on.
    Sam
  9. Andre_B
    Andre_B Minimodder
    17 May 2009
    samkiller42 likes this.
  10. samkiller42
    25 Apr 2006
    Thanks Andre_B, i hadn't tried Port Triggering, just read that it 'can' help, However, using the page you've linked, it's worked, so far :Thumb: So cheers for that.
    Sam
  11. Andre_B
    Andre_B Minimodder
    17 May 2009
    Great, lets hope it keeps on working. :)
  12. Buzzons
    Buzzons Minimodder
    21 Jul 2005
    Best solution would be using real IP addresses not NAT'd ones as the ports that they may use could conflict. However, if you're not with a decent ISP then you'll only be given one of these at best.
  13. LightningPete
    LightningPete Diagnosis: ARMAII-Holic
    2 Jul 2009
    Im sure i read not to long ago that much of the time its to do with the IP addresses of invidual homes. I.e. your home only one IP address but two xbox live accounts running from it causing the conflict. There are means and ways which you appear to be exploring, however this appears to be that very same problem I have read about.
    If you have another modem/router where your internet comes in, use instead to see if this makes a difference?
  14. notmeagain
    notmeagain Minimodder
    29 Jan 2009
    it's more likely to do with NAT related issues, and your router being overzealous with the port allocation.
