Apple 2.5" SATA Hard Drive
Discussion in 'Software' started by seebul, 10 Dec 2006.
  1. seebul
    seebul Minimodder
    9 Aug 2005
    Hi, im buying a White Macbook next week :rock: And ive been looking for a replacement hard drive for it but i cant find anything above 160GB, i want a 200GB one but i cant afford to pay apples upgrade prices, anyone know where i can find one? (UK)
  2. unrealhippie
    unrealhippie What's a Dremel?
    24 Jul 2004
    Just buy an external drive, surely 120gb is enough for around and about?
  3. seebul
    seebul Minimodder
    9 Aug 2005
    thanks for the reply but i dont want to have to carry around something extra + i need a huuuge hard drive as its going to be used for HD video editing and also i would like to install windows on it.
  4. ElThomsono
    ElThomsono Multimodder
    18 Mar 2005
    I just checked Seagate, Western Digital, Fujitsu, Maxtor and Samsung, none of them make anything above 160GB.
    I think the reason you can't find them is that they don't exist. I'm not certain, but have you ever actually seen one?
  5. crazybob
    crazybob Voice of Reason
    21 Oct 2004
    http://www.newegg.com/Product/Product.asp?Item=N82E16822149059
    As far as I can tell, that's the only one on the market, and presumably the one Apple installs. However, with 160GB drives running around $170(£85), you have to ask yourself if another 37GB (once corrected for manufacturer GB vs real GB) is worth almost $100(£50).
  6. cderalow
    cderalow bondage master!
    23 Jan 2002
    the better question would be, why in god's name are you getting something with onboard video to do video editting?
  7. seebul
    seebul Minimodder
    9 Aug 2005
    Ok thanks for the replies guys,i may just get a 160 gb hard drive then.
  8. Valo
    Valo Minimodder
    11 Aug 2004
    toshiba does 200gb sata portable drives afair, also, there's a rumour that fujitsu is going to release perpendicular 300gb 2.5 sata drive in january
  9. bennifer
    bennifer What's a Dremel?
    26 May 2004
    because video editing is a really processor intensive task and barely touches the graphics card (unless you're doing stuff in apple motion or after effects). if you arent doing any kind of 3d rendering its much more cost efficient to go for a macbook over a macbook pro - same beasty processor, nice and portable.
  10. cderalow
    23 Jan 2002
    only the pro systems architectures are designed and optimized for graphic, video & music editting.
    not to mention most software suites for graphics and video still haven't been released as universal binaries, so they don't run at their most efficient under rosetta...
  11. kylelnsn
    kylelnsn What's a Dremel?
    19 Dec 2006
    buy a desktop? that woudl be a good idea! no nice looking laptops tho thye are good, dec proc and v gd for wat u need it for! nice one! CLICK BUY
  12. Phrozenpenguin
    Phrozenpenguin What's a Dremel?
    11 Dec 2001
    The Macbook is a great little machine even for running Pro apps like Final Cut (which is Universal.) No for Motion.
    As for the topic I would recommend an external drive for editing though. Fast, cheap and straightforward. Although you cannot use it to boot windows (why do you want to!)
  13. airchie
    airchie What's a Dremel?
    22 Mar 2005
    The 200GB HDD, even though it has 8Mb cache is only 4200RPM!
    Far better with a smaller 7200RPM disk for video editing surely?
    I'm not sure since I'm no video editor but all the posts I read about video editing recommend raid 0 for increase disk throughput.
