Storage 2.5tb Drive shows up as 280gb
Discussion in 'Tech Support' started by [<x>] Kiyusoma, 1 Dec 2012.
  1. [<x>] Kiyusoma
    [<x>] Kiyusoma Deus Ex Machina
    16 Jun 2004
    Just installed new 2.5tb drive and when windows asked me to initialize it, I accidentally selected MBR instead of GPT, so I changed it back but drive still shows as 280gb. Motherboard is ASUS P5B Deluxe.
    Intel Matrix Storage Manager is installed and sees the full 2.5tb. How do I correct this?
  2. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    Go to disk management and delete or extend the partition
  3. [<x>] Kiyusoma
    16 Jun 2004
    no volumes shows as unallocated
  4. RichCreedy
    24 Apr 2009
    You may need a bios update
  5. [<x>] Kiyusoma
    16 Jun 2004
    BIOS is at latest
    EDIT: I fixed it, needed intel rst v 10.1.0.1008 vs Intel Matrix
  6. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    open cmd as admin, diskpart, select disk ?: (be very careful to select the correct disk), clean all
    should remove the partitioning and hidden sector info allowing you to start over.
    If that dosen't do it for some reason might need to boot into gparted and have a go there.
