Modding 2 loops in a Stacker 830 Evo
Discussion in 'Modding' started by ledbythereaper, 29 Dec 2007.
  1. ledbythereaper
    ledbythereaper What's a Dremel?
    2 Jan 2007
    Planning on replacing my Eclipse with the 830 Evo, however I want to know if you can fit a 2nd 240 rad in the case anywere other than the side panel (it's being replaced with acrylic or without loosing drive bays.
  2. Guest-23315
    Guest-23315 Guest
    You could fit one in the front 5.25" Bays, or one on the bottom panel, or using a Swiftech Radbox, mount it off the rear 120mm fan on the motherboard tray.
  3. ledbythereaper
    2 Jan 2007
    I'm already going to have 1 in the bottom 240 part. I just wanted all my w/c to be internal, will there be enough space to have the hard drive cage, drive bay res and a dvd drive with a 240 in the front?
  4. Guest-23315
    Guest-23315 Guest
    Nope. You've got 9 5.25" bays, and a 240mm Rad takes 5.5-6.5 of them.
