Modding 2 motherboards on one case
Discussion in 'Modding' started by doryakov, 26 Jun 2007.
  1. doryakov
    doryakov What's a Dremel?
    8 Aug 2005
    i want to put two motherboards on one case . i think about to build a new case and design it or take old case and mod it . any suggestion ?
  2. Spaceraver
    Spaceraver Ultralurker
    19 Jan 2006
    Double the amount of components ie. anything that normally only exist in one copy need to be doubled. And you can easily do that.. Unless you're planning a render farm sharing a psu isnt recommended. Just remember that it will get hotter in that case and you need ample cooling..
  3. Duste
    Duste Sierra my delta, bravo!
    1 Oct 2006
    There are cases around, namely MountainMods' cases, that can support two motherboards without any modification.
  4. Guest-23315
    Guest-23315 Guest
  5. beesbees
    beesbees What's a Dremel?
    29 Apr 2007
    That page makes no sense?
    So, is it in or out of stock?
  6. Hazardous
    Hazardous What's a Dremel?
    21 Jan 2004
    That's exactly what I was thinking as well :idea:
  7. Hugo
    Hugo Ex-TrustedReviews Staff
    25 Dec 2006
    I think it means that usually the cases are held in stock so they dispatch when you order as opposed to some companies who receive your order, then order from their suppliers before shipping to you.
    So basically, no they have none in stock. (as I read it)
    Cool idea though!
  8. Guest-23315
    Guest-23315 Guest
    They can get them in in foru to five days for you, as opposed to weeks from other e-tellers.
  9. aquatuning
    aquatuning What's a Dremel?
    5 Jul 2006
    Hi all,
    Yes it means we buy the cases in and hold them in stock instead of ordering them on request - these have been very very popular so they have sold out.
    Also if you have a request we can get the cases in the UK in 4-5 Working days :p
  10. C-Sniper
    C-Sniper Stop Trolling this space Ądmins!
    17 Jun 2007
    now THATS a case!
  11. doryakov
    8 Aug 2005
    i will build it from perspecs . the case will be a cube . when i sketch it i will show you the pictures .
  12. Butcher9_9
    Butcher9_9 What's a Dremel?
    15 Sep 2006
    i know some one that built a case with 2 mobos in it . it was like the ultimate lan case , one pc for leeching and the other for gameing
    its pretty much just 2 atx case welded together , one case was reversed abit and a lcd stuck on the front + there was abit of plastic work to cover the welds ect
  13. doryakov
    8 Aug 2005
    it's very big . i want to build a new case . the size will be 33X33X40cm .
  14. identikit
    identikit Minimodder
    5 Jun 2004
    My old record was one eATX and a mATX with a stripped down router somewhere in the mix. I put passive heatsinks on everything and then mounted the mobos close together and made a wind tunnel to cool it down. If I scratch built the case instead of modding it, it could have been half the width of a regular case.
  15. _crazy_crazy_
    _crazy_crazy_ mi mum say's that i'm special
    1 Feb 2007
    i've done something like that but i was wondering whats the best way to connect the two mb ? i wanted to just use teh interface of a single pc use them both like a single pc ....
    any one knows how ?
    somebody told me something about cluster ?
    would that work?
    after i'm finished i'll post some pic's
  16. MrP
    MrP seeking inspiration
    5 Jul 2007
    i had an old dell server case about 5 years ago that i shoved 2 full ATX motherboards, and a m-atx motherboard in, all the required hard disks, and 2 psu's (1 shared)
    i never got around to finishing it as a seti farm :(
    the easiest way would be to setup each with a windows install, and then use something like VNC to connect to each machine over a network.
