Scratch Build – In Progress 2 of 3 Project :: CNCB (CNC Controller Box) , Finish 18/09/2013
Discussion in 'Project Logs' started by iD2, 4 Sep 2013.
  1. iD2
    iD2 Minimodder
    25 Mar 2012
    Welcome!!!​
    See all project at my blog here :: iD2CNC.wordpress.com
    Project No. :: 2 ,(2 of 3)
    Project Name :: iD2CNCB v.1.0
    Project Description :: This project i will make CNC Enclosure box and put PC Component into same enclosure (include 15" LCD Monitor) .
    Project design ::
    Specification ::
    Dimension :: 540x390x320mm (WxHxD)
    Finished 1st project ::
    Incoming 3rd project ::
    Project No. :: 3 ,(3 of 3)
    Project Name :: [GT] Carbide Series
    Project Concept :: It not just system , it your Style
    Project Description :: This project i will go to an acrylic PC case. I design it to transparent both side and font panel to show what's your style inside or how your style inside.
    Project design ::
    6 Colors to compatible with your component
    All Project by ::
    Hope you like it.
    PS. I'm not good in English , If i make you confuse please feel free to ask me.
  2. iD2
    iD2 Minimodder
    25 Mar 2012
    Start cutting aluminum profile
  3. iD2
    iD2 Minimodder
    25 Mar 2012
    Left Panel cutting.
  4. dynamis_dk
    dynamis_dk Grr... Grumpy!!
    23 Nov 2005
    Fantastic work, very keen to see a few 'in action' videos again of the CNC cutting the panels for the case.
    Always loved how a lot of CNC designers build a smaller machine which they then use to cut parts to build a bigger machine - and it goes on and on lol.
    Will keep an eye on this log too as the CNC machine one was great :)
  5. iD2
    iD2 Minimodder
    25 Mar 2012
    Thank you, some parts already finished cut i'll take some video of font panel cutting soon.
  6. iD2
    iD2 Minimodder
    25 Mar 2012
    Right panel cutting finished.
  7. dynamis_dk
    23 Nov 2005
    What type of cutter do you use? RPM? The cuts are so clean!
  8. iD2
    iD2 Minimodder
    25 Mar 2012
    I use
    Endmill = 3mm 4 Flute
    Spindle speed = 18000 RPM
    Deep of cut = 2mm
    Cutting speed = 500 mm/minute
  9. Furball Zen
    Furball Zen Shut up and Mod
    25 Jan 2012
    Wish i could buy a CNC flat packed from you :D
  10. iD2
    iD2 Minimodder
    25 Mar 2012
    Sorry for not update progress because my storage HDD was dead and it cause my windows problem and it can not boot , i need to install new windows and try to get my data from my storage HDD back.
    OK, update my progress now.
    Top panel ::
    Middle panel ::
    Spray paint ::
  11. iD2
    iD2 Minimodder
    25 Mar 2012
    :D
  12. iD2
    iD2 Minimodder
    25 Mar 2012
    Big update. Start assembly most of all components but still need to finish font left panel , font right panel and back panel too.
    Note :: Sorry for some image quality.
  13. Cheapskate
    13 May 2007
    Awesome!:D
  14. dynamis_dk
    23 Nov 2005
    Outstanding work... only one very minor criticism because I'm picky :p
    Where you have the 3 connectors for power (http://id2cnc.files.wordpress.com/2013/09/id2cnc-assemblyenclosure-14.jpg?w=640), given the tooling you have access to I personally would have cut the holes to allow the mounting tabs to be on the inside of the case so externally you don't see the mounting tabs, just the socket for the power to fit flush with the case... like it said tho - I'm picky lol
  15. iD2
    iD2 Minimodder
    25 Mar 2012
    Sorry for reply late just got an accident with my finger.
    For 3 connector ,i need to split every tool i use because if it don't need to use something i can turn it off and why i'm not hide mounting tabs because i don't need to working with both side of acrylic and i need to finish it as soon as i can but your advice was good i'll do it in next project.
    If i make you confuse please feel free to ask me , i'm not good in English
  16. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    Really loving this project.
  17. iD2
    iD2 Minimodder
    25 Mar 2012
    Sorry for nothing update for a couple week , i got an accident with my finger from knife and it need to surgery.
    So i can't do it as normal but i'm try to finish and i'll do it as i can.
    PS.sorry for images quality , my hand it a bit shaking when take picture
    Font right panel ::
    15" Monitor mounthing ::
  18. iD2
    iD2 Minimodder
    25 Mar 2012
    Finish power wiring and finish assembly.
  19. iD2
    iD2 Minimodder
    25 Mar 2012
    sorry for image quality. (If i can find my camera stand i'll update new picture)
  20. -Jv-
    -Jv- What's a Dremel?
    29 Mar 2011
    Holy ****, that's just amazing.
