Cases 2 options for a new case (water cooled)
Discussion in 'Hardware' started by unknowngamer, 14 Aug 2009.
  1. unknowngamer
    unknowngamer here
    3 Apr 2009
    I've narrowed it down to 2 cases.
    Cosmmos S and Antec 1200
    I'll be using a standard 3x120 and 2x120 rads.
    With ddc+ with res top CPU and single GPU blocks.
    For the cosmos S, the tripple in the top and the double in the front drive bays.
    For the Antec, Tripple in the front (drive bay) and the double flush screwed to the rear
    leaving the fans inside bolted to the rad outside, to make the rad fit flush against the chassis
    I think the antec can be done well, and done tidy.
    Pump > Cpu > double rad (outside case) > GPU >Tripple rad > Pump
    I've got 90 degree elbows so I'd need to 90 degree bend in 8 Cm
    what do you think.
    try it. or just go with the cosmos S 'cos it's easy.
    Any feed back would be cool, I'll be getting in sometime friday to collect from scan on Saturday, so info asap Please.
  2. Fazed
    Fazed Minimodder
    5 Jul 2009
    Depends how much of a challenge you want!
    Personally, I'd opt for the tried and trusted Cosmos for Watercooling.
  3. Digitalize-
    Digitalize- What's a Dremel?
    23 Apr 2009
    I'd love to see a 1200 with a triple rad in the front, go for it (Y)
  4. Elton
    23 Jan 2009
    ATCS 840.
  5. JaredC01
    JaredC01 Hardware Nut
    24 Nov 2002
    Wasn't one of his choices. ;)
    I'd love to see if the 1200 IF it can be done. I'd look into some specific measurements before making a decision on it.
    That being said, I absolutely love the look of the Cosmos 1000, and the Cosmos S. If only I could have picked up one of the Black Labels when they were out... It's everything I wanted in a case. :(
  6. unknowngamer
    unknowngamer here
    3 Apr 2009
    I went for the Antec, just to be different.
    Wish me luck with this.
    Could be an expensive mistake
  7. [ZiiP] NaloaC
    [ZiiP] NaloaC Multimodder
    9 May 2008
    I just can't bring myself to like the Antec X Hundred cases. I don't know why, but never really appealed to me.
    That being said, it would be nice to see one of them WC'd as apposed to a Cosmos which has been done time and again.
  8. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    There's still one for sale in Hungary, if you're desperate enough.
    But more realistically, CM recently came out out with a mass-produced black Cosmos anyways.
  9. pistol_pete
    pistol_pete Air Cooled Fool
    7 Jan 2008
    For the ultra-win, put a slim DVD in the bottom of the case and fit a quad rad in the front!
  10. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    For going with the Antec 1200 your either brave or stupid :thumb:
    But seriously, I truly wish you the best although the Cosmos S would have been a hundred times easier and better but its up to you...
    Air cooling - Antec 1200
    Water cooling- Cosmos S
    That simple
    EDIT: Dude you missed out big time:
    http://www.novatech.co.uk/novatech/specpage.html?cm-cosmosb
    sell your 1200 and buy it NOW NOW!!!!
  11. JaredC01
    24 Nov 2002
    The Pure is nice, but I want the window to show off my sexy hardware... The Black Label is EXACTLY what I want, but I will probably settle for a Corsair Obsidian 800D.
    Good luck with the 1200. :)
  12. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    click my above link!
  13. JaredC01
    24 Nov 2002
    I'm in the US... :(
    The Pure listed on CM's site doesn't have the side panel window... Wtf.
    I would have ordered one when they were in stock a few weeks back if I had seen a window.
  14. unknowngamer
    unknowngamer here
    3 Apr 2009
    The standard cosmos sucks for major water cooling
    Has to be a cosmos S
    As for brave or stupid
    I'll wager you an "e-pint" (make/get A good photo of a pint with your or my name in it, depending who is righ)
    I bet I can get a "tidy" double and tripple rad in an antec 1200 with no bits hanging off the outside.
  15. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    Well... I don't drink but... ITS AAAWWWNNN!!!
  16. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    Update please on how your build is going?
    EDIT: Pics would be nice so I can mock you with scrupious detail
  17. MaverickWill
    MaverickWill Dirty CPC Mackem
    26 Apr 2009
    Protip - the dual rad for the rear can fit on the inside, so you don't have to bother with an external rad. Just a thought...
  18. Eddieboi
    Eddieboi What's a Dremel?
    27 Jun 2009
    Just bit of advise about that antec case, with that 240 being mounted externally I suggest you get some longer screws than the ones provided as the rad will fit a bit weirdly due to the extruding 120 x 2 fan vents on the rear of the case...yes I did have an antec 1200 case and yes my PC is Watercooled...I actually went for a 240 x 2 rads in the front bottom 2 drive bays, worked fine and I Could fit my 2 x DVD rewriters and my card slot thing and my 1 drive water bay.
    With that 360 rad in the front your gonna need a drive mount for it such as a sharkoon rebel fan fram Clicky to mount your 360 rad in the drive bays
    PS the 240 rad can fit internally but I believe you need to get the right sized rad to allow it to be mounted on the rear fans internally, as with the big boy fan at top I found it does extrude a bit more than I originally thought, someone has done this without any problems from a picture I saw but no idea what rad brand or make it is
  19. MaverickWill
    26 Apr 2009
    XSPC RS240 here - no problems mounting it internally. Of course, you don't to worry QUITE so much about the Big Boy's airflow if you're water-cooling everything. It'll sure help, though, so yeah, that's a good call on checking. The RX240, for example, might be slightly more restrictive.
  20. unknowngamer
    unknowngamer here
    3 Apr 2009
    Done.
    Leak testing now.
    just sorting out the photo's
