2 or 4GB of ram?
Discussion in 'Hardware' started by 1e8o, 28 Aug 2007.
  1. 1e8o
    1e8o New Member
    13 Oct 2005
    I already have 2 GB's of Ram.
    Does the 2 extra GB give you an performance boost or isn't it worth the money.
    Thanx already :thumb:
  2. naokaji
    naokaji whatever
    8 Dec 2006
    short answer: No.
    (somewhat) long answer:
    4 GB Ram wont give you an advantage in many applications, in the ones that would the rest of the system would bottleneck it...
    2 GB is enough atm... i'd wait till ddr3 drops in price and then buy 4 GB of it sometimes next year.
  3. Mother-Goose
    Mother-Goose 5 o'clock somewhere
    22 Jul 2004
    Depends what OS you are running, Vista will make a diff, even if it's 32-bit and limited to 3.25gb it makes a noticeable difference
  4. naokaji
    naokaji whatever
    8 Dec 2006
    well.. yes and no...
    yes if you run ms bloatware (srry, vista) in default config... no if you strip down vista to the point where it doesnt have all the useless stuff anymore.
  5. Guest-23315
    Guest-23315 Guest
    I'd rather have 4Gb of fairly basic RAM that have 2Gb of fairly decent RAM.
  6. Ramble
    Ramble Ginger Nut
    5 Dec 2005
    Vista will only use up what it wants depending on how much RAm you've got and how much is free (you fanboy).
    Doubt you'd see much of a performance difference TBH, maybe later.
  7. wuyanxu
    wuyanxu still wants Homeworld 3
    15 Aug 2007
    from what i can understand:
    -for 32bit, 2gig is perfectly fine
    -for 64bit, 4gig is better.
    so i have bought 2gig for my q6600, and will be buying 4 more gigs to get up to 6gig when upgrading to 64bit
  8. dimebar
    dimebar New Member
    26 Jul 2003
    ive been on vista 64 now since release, and have started to struggle on 2gb and readyboost, so im going 4 gig soon.
    so in 64 bit you shall se a difference, in 32bit it is far less pronounced
  9. cyrilthefish
    cyrilthefish New Member
    15 Apr 2004
    Personally i think RAM is one of the most understated parts of a PC.
    Though it does depend what type of programs you use though.
    I play a fair bit of MMO's, which have a habit of eating RAM for breakfast. A few years ago i upgraded my old PC from 1GB to 2GB, the performance difference in WoW was immense ;)
    I haven't tried 2GB in my PC: but with 4GB, after the 1st time initial game load for bioshock, the level changes are lighting quick :clap:
    had to swap to 64bit XP to get the full 4GB to be detected though :hehe:
  10. 1e8o
    1e8o New Member
    13 Oct 2005
    I went from 1 gig to 2 gigs and the difference was very noticable. Under vista you defently need 2 gigs. Only problem is that my old memory would work together with the new one. otherwise I had had 3 gigs of memory. Does anyone have a solution to this? I dont think so but its worth te try :p thanx already for all of the answers
  11. Mother-Goose
    22 Jul 2004
    If you did that then there is sod all point of having vista in the first place imo.
    I've had 4gb on both 32-bit and 64-bit Vista, you can tell the difference between 2 and 4, (I had a period where 2gb was being rma'd) With 32-bit I think you have to install with 2gb and then do the updates and then plug the other 2gb in, and you do get a performance increase, I found it quite noticeable.
    My rig is similar to dimebar's in most respects and I trust him :)
  12. Bbq.of.DooM
    Bbq.of.DooM Custom User Title
    12 Feb 2005
    Rig in sig? Then no.
  13. Mother-Goose
    22 Jul 2004
    Not sure what you are getting at bbq.
    A quick note with running 4gb on a 680i, no point in getting 8500 or above.
    I had 4gb of 9200 flex xlc to start with and it won't run stable above 1000mhz. (2gb would without much problem) So you are better off getting some 6400 and OC'ing it (or run it at stock like I do) OR get some 8500 that's not oc orientated (some OCZ sli stuff would suit).
    But in answer to your question yes get 4gb, just don't spend loads on high performance stuff because you won't get it running flat out :)
  14. 1e8o
    1e8o New Member
    13 Oct 2005
    I think I stick with the 2 gigs at the moment, Going for 4 on my new rig. Directly to ddr3, I don't really need a new one at the moment. I can do everything with it what I want to do with it :D
  15. Mother-Goose
    22 Jul 2004
    That makes sense to me :)
