Modding 2 PSU's one case?
Discussion in 'Modding' started by Prometheus_99999, 19 Oct 2003.
  1. Prometheus_99999
    Prometheus_99999 What's a Dremel?
    13 Apr 2003
    Ok i have got two old pc's that i am gonna take the good things out of and put together to get a half way decent mp3 player. Also i am gonna use the case to mod and get the hang of things. So what I am wondering is if there is anything that would be wrong with having 2 PSU's in a case. I wold have one on top of the other. One would run lighting and other things in the case and the other would run the computer. So would this work ok or is there anything that would cause trouble. Also would i need to power switches, one for each PSU.
  2. Astrum
    Astrum Dare to dream.
    8 Mar 2002
    Theres no problem with two PSUs. A lot of people have two, one for their actual computer and the rest for their lighting and other fancy features.
    Theres an article somewhere on multiple PSUs... Can't seem to find it, anyone know the link?
  3. Prometheus_99999
    13 Apr 2003
    Ok thanks for the info. I will install that after i finish making my hardrive racks. Well since i am not sure about this might as well ask. If i have the bottom of my hardrive on metal it wont hurt it any, or should i put somethingto stop the contact of it with the metal.
  4. Astrum
    8 Mar 2002
    There should be no problem if your HDD (case) is in contact with metal. In normal conditions anyway.
  5. Prometheus_99999
    13 Apr 2003
    Ok thanks for the help now i just have to finish the first rack and make another then put in the psu and finally paint the whole thing.
  6. Kobalt
    Kobalt What's a Dremel?
    26 Aug 2003
  7. Astrum
    8 Mar 2002
    Thanks for the link Kobalt. I was looking for a similar article but I couldn't find it :(
  8. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    I believe that modfathes also had a dual psu guide.
  9. Astrum
    8 Mar 2002
    A plethora of sites have it. Its just way too hard studying concepts of infinity and theories thereof AND finding the an article on dual-PSUs :D .
  10. Kobalt
    26 Aug 2003
    Actually i just did that one today,lots of peoples were asking the same thing :worried:
  11. Twernmilt
    Twernmilt What's a Dremel?
    23 Sep 2003
    how many watts do your PSUs spit out? you may not need 2
  12. Astrum
    8 Mar 2002
    A normal system only requires about 300-400W. Systems with multiple HDD's, multiple disk drives and such obiously require more.
    If you have quite a lot of lights (LEDs, CCFLs, etc...) and other visual effects its better (in my opinion) to use two PSUs. Of course its really up to you.
  13. Kobalt
    26 Aug 2003
    I didn't do the maths but in my case (i like light stuff) i tought why risk it, better use 1 for the important stuff hdd's cpu mobo and another one for lights and mods, you never know. in any case i'd rather have 2 cold ones than a overloaded one ;)
  14. Tulatin
    16 Oct 2003
    Having a second is also great when you refuse to pay $150 for a dedicated pelt psu...
  15. taliban_raider
    taliban_raider Just some guy; you know
    28 Feb 2003
    I am having 2 in my latest mod I am working on I am converting an at case to atx and the powersupply cassing in it was massive So I am going to put an atx 300w poowersupply and an at 500 wat powersuply ans just have the at switch on using a relay powerd off the atx.
  16. Tulatin
    16 Oct 2003
    What you can also do, is try soldering green and black from the two atx connectors together (rather running wires between pins)
  17. Prometheus_99999
    13 Apr 2003
    The one that runs the installed system is a 250 watt. The other one is a 150 i think. This system is really only gonna be used for a mp3 player and to practice modding on until i get my new computer so would the 150 watt one be good enough to power the extra stuff like lighting. Also would it be at all possible to wire up christmas lights to a molex connector cause that would be cool. :rock:
  18. Tulatin
    16 Oct 2003
    Christmas lights are 120-240 volts, depending on which side of the pond. Hook em to ac.
  19. taliban_raider
    28 Feb 2003
    Not necissarily low voltage out door ones are usuly six - 12 volts but they arnt usuly coloured and they look poo.
  20. Prometheus_99999
    13 Apr 2003
    Ok thanks i think i will just stick with LED's for lights.
