Displays 20" VGA 12V DC - complete - thanks
Discussion in 'Hardware' started by Kalcifer, 27 Jun 2011.
  1. Kalcifer
    Kalcifer If you want change, start with yourself.
    23 Sep 2009
    Hi All
    Been tasked with trying to find a monitor for a role at work, google has failed me so far as it's hard to search for the specs I need, wondering if anyone has any suggestions, either for the monitor, or a good place to start searching. So far I've tried RS, Scan and Overclockers.
    A 12V DC, VGA 20" Monitor which uses an external power adapter.
    External Adaptor is so we can wire the monitor directly to our rig without rerouting a mains power supply.
    This would be a one off purchase and not a bulk buy.
    Any suggestions or advice you could give would be really appreciated.
    Thanks:thumb:
  2. Kalcifer
    23 Sep 2009
  3. Kalcifer
    23 Sep 2009
    Unfortunately the LCD I found, though it had all the specs I wanted, it doesn't have a wall mount, so my search has resumed. :-(
  4. Xir
    Xir Modder
    26 Apr 2006
    Kalcifer likes this.
  5. Kalcifer
    23 Sep 2009
    Thanks, I think these could be just what we need. +rep :D
  6. Xir
    Xir Modder
    26 Apr 2006
    Thx :thumb:
    I looked ages to find a decent one for my parents Campervan :D
