200gb HDD shows as 137gb
Discussion in 'Hardware' started by soopahfly, 3 Jul 2008.
  1. soopahfly
    soopahfly Minimodder
    12 Jan 2002
    Alright ladies and clever people, age old problem with a new twist.
    I've got a Western Digital 200GB ATA hard drive, that has been sat for a while in my desktop and i've never really paid much attention to it.
    Took the dead HDD out of an old Maxtor Onetouch enclosure and discovered my HDD shows as 137gb. Odd I know, i'd have understood if I was running XP with no service packs like back in the day but it shows as such on my OpenSUSE11 laptop and my SP3 XP machine.
    Anyone got any ideas as to how to make it show its full capacity?
  2. r4tch3t
    r4tch3t hmmmm....
    17 Aug 2005
    It may be partitioned to 137, get Diskwizard and reformat it to the full capacity.
  3. soopahfly
    12 Jan 2002
    Its completely empty, no partitions nothing, so I would have thought that it would just format it at the size it shows when there are no partitions on it?
  4. cpemma
    cpemma Ecky thump
    27 Nov 2001
    It may have a hidden "recovery" partition, Dell style, do you know what it was originally installed in?
  5. kenco_uk
    28 Nov 2003
    It may be limited via a jumper.
  6. r4tch3t
    r4tch3t hmmmm....
    17 Aug 2005
    Those are annoying, had one of those once, took me ages to figure out.
    If its empty get the Ultimate boot CD or a copy of Ubuntu and reformat it from there. There may be hidden partitions that can't be seen from Windows.
  7. soopahfly
    12 Jan 2002
    Thats a good point actually, as it did originally come from an Acer.
  8. Ramble
    Ramble Ginger Nut
    5 Dec 2005
    Do hard drives disable sections of the platter than have become damaged?
  9. Firehed
    15 Feb 2004
    Yes, but if you've lost a third of the drive to that, you've got bigger problems.
  10. soopahfly
    12 Jan 2002
    Interestingly enough, it only detects as 137gb in the bios. I've got 200 and 250gb SATA drives that detect fine.
  11. Langer
    Langer Jesse Lang
    24 Jan 2004
    Has the drive ever posted 200GB? if not you may have somehow stumbled on a ridiculously under sized drive from the factory.
    More likely is that it has a jumper.
  12. r4tch3t
    r4tch3t hmmmm....
    17 Aug 2005
    I agree, if the BIOS detects 137GB it's a jumper. Else... well I don't know.
  13. ComputerKing
    8 Sep 2006
    137GIG is too low... I think there is partition or Jumper. It should be around 170 - 189 GIGS, Maybe it have a ghost image or some thing on a hidden partition or the back up one. Otherwise I can't help :( Good luck my buddy
  14. ConKbot of Doom
    ConKbot of Doom What's a Dremel?
    2 Jul 2003
    definitely a jumper. kinda like seagates always coming with the speed limited to 1.5 gbps, and you have to take the jumper off for 3.0 gbps
  15. soopahfly
    12 Jan 2002
    Western Digitals have no such jumper :S
  16. r4tch3t
    r4tch3t hmmmm....
    17 Aug 2005
    Have you tried it in another computer or with a USB enclosure?
  17. Daniel114
    Daniel114 What's a Dremel?
    9 Sep 2007
    Both my raptors were found as 137 gig in windows, can't remmember what I did but now there at 150, so its not a smaller drive, its some sort of preset... hang on I'll try and find out
    Edit - here http://www.techsupportforum.com/har...e-support/141408-western-digital-250-gig.html it just says to goto comp management and sort it there, I remember there being an SP1 problem with drives over that size, but that wouldn't explain bios or Suse
  18. soopahfly
    12 Jan 2002
    The onetouch enclosure originally had a 250gb drive in it, which my PC detects as a 250, along with my other drives. The Laptop runs suse and also detects it as 137.
    WD Tools on a certain boot disc sees 137 :S
  19. Smegwarrior
    Smegwarrior Fighting the war on smeg
    19 Nov 2007
    Seagate's Seatools program is able to restore the HDD to it's native size, it says it will work on any HDD not just theirs.
    I used it on 1 of my 120GB HDD's that showed correctly in BIOS and Vista but when tested with Seatools showed it was slightly smaller, I ran the restore function and it fixed it.
    Though I still get a boot disk failure error when I install service pack 1.
  20. Hazardous
    Hazardous What's a Dremel?
    21 Jan 2004
    What OS?
    137GB is a pre-XP SP2/SP3 hard drive capacity limitation :idea:
