Cases 200mm fans ???????
Discussion in 'Hardware' started by Kovoet, 15 Jul 2011.
  1. Kovoet
    Kovoet What's a Dremel?
    26 Aug 2009
    I just got some black and white fans for my HAF "X" case the 200mm ones from NZXT but they do not fit where the old coolermaster fans fitted.
    I can drill holes and so forth which is not a problem but has anyone found this to be a problem when getting NZXT fans
  2. Jipa
    5 Feb 2004
    I don't think there's a real standard for the 200 mm fans, they seem to come in all sorts of shapes with the mounting holes being all over the place. Dunno about the NZXT's specifically, but this is the feeling I have after reviewing plenty of cases with 200 mm fans...
  3. Kovoet
    26 Aug 2009
    Thanks for the feebback
  4. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    I think the HAF uses 220mm fans...
  5. Kovoet
    26 Aug 2009
    thats what I thought as well but checking the website it says 200mm
  6. Wira
    Wira Spoderman
    27 Jan 2011
    I had a similar problem, mounting for 200mm fans seem to be up to the manufacturer.
  7. .//TuNdRa
    .//TuNdRa Resident Bulldozer Guru
    12 Feb 2011
    NZXT 200MM fans are actually 192MM, with mounting holes to suit (Rage.)
    Go for some BitFenix fans or others, they're just as good, and they're actual 200MM fans.
  8. Kovoet
    26 Aug 2009
    Good find and thanks. The reason i went for these is the colour and cannot trust myself painting fans.
  9. Bloody_Pete
    11 Aug 2008
    If you can take the fans apart, its really easy :)
  10. Kovoet
    26 Aug 2009
    you talking to me Pete these hands are made for breaking things. I do not know my own strength.
    Theres loads of wheel and car bolts lying around this earth that I have broken
