Case Mod - Complete ⭐ 2019 Thermaltake CaseMOD Invitational Season 2 - ZenModz Build log
Discussion in 'Project Logs' started by Zenator, 15 Sep 2019.
  1. Zenator
    Zenator Minimodder
    12 May 2015
    Hello again. It has been quite some time since I have posted on any forums. The beginning of a new adventure is always fun. :) My First time invite to the 2019 Thermaltake CaseMOD Invitational Season 2 with a very big thank you to TT for the invite and to all the sponsors.
    And to all who may look upon this build I hope you enjoy the ride. :)
    Theme is going to be very old. You will see in time. :p
    Will post photos soon.
  2. Zenator
    Zenator Minimodder
    12 May 2015
  3. Zenator
    Zenator Minimodder
    12 May 2015
    Hello, This will be the Theme I am going to be going with. I will be using lots of different techniques in this build. Tools used will be, AI, PS, Laser, Cnc,, Hand Sculpting. 3d printer. Airbrushing. and the good old paint brushes. Pulling out all the stops on this one. Should be fun. :p
    No hacksaw-ING the tubing this time. :) This kit should make this much easier to work with.
  4. Zenator
    Zenator Minimodder
    12 May 2015
    TT Riing Trio have arrived. :)
    PSU & MOBO fitted. :)
    More Soon. :)
  5. Zenator
    Zenator Minimodder
    12 May 2015
    All the cooling fittings have arrived. The 6 Packs are a very nice look. :)
    Thanks for stopping by. :)
  6. Zenator
    Zenator Minimodder
    12 May 2015
    3600MHz 4x8 of RGB Bliss
    Yury and douglas alves like this.
  7. Yury
    Yury What's a Dremel?
    7 Mar 2019
    Following
  8. Zenator
    Zenator Minimodder
    12 May 2015
    Hello again, Some interesting work photos this time. And I go my first ever 3d printer. Ender 5. with lots to learn in a short time frame.
    Meet the start of Mr T-Rex. and many more Dino's to come. [​IMG]
  9. delevic
    delevic What's a Dremel?
    21 Feb 2015
    Interesting, waiting for progress.
  10. Zenator
    Zenator Minimodder
    12 May 2015
    Hello again everyone. :)
    3D printing take some work and to when you stuff it up you learn to rebuild.
    Not a very good try.
    Need a bigger raft to hold it.
    Much bigger :)
  11. Zenator
    Zenator Minimodder
    12 May 2015
    Now this is looking better. :)
    Thanks for stopping by, More again soon.
  12. Zenator
    Zenator Minimodder
    12 May 2015
  13. Zenator
    Zenator Minimodder
    12 May 2015
    Dot_Kappa likes this.
  14. Zenator
    Zenator Minimodder
    12 May 2015
    Laser cutting profile ready to go. [​IMG] I can not wait to get started on this part. :p
  15. Zenator
    Zenator Minimodder
    12 May 2015
    I never though I would ever have a need for spray expanding form.
    censored_Prometheus_ and Vandalo like this.
  16. Zenator
    Zenator Minimodder
    12 May 2015
    Hello again, So now I have most of the background blocked out. it is now time too add some details to match in with the first part.
    Using a soft wire brush will the Dremel to remove excess foam and not damage the plastic & paint parts.
    The rest is of it is a bit more time consuming.
    More again later. Thanks for stopping by. :)
    censored_Prometheus_ likes this.
  17. Zenator
    Zenator Minimodder
    12 May 2015
    Not much to say, Just more painting. [​IMG]
  18. Zenator
    Zenator Minimodder
    12 May 2015
    Starting to get the ground colour down, still much more to do on this part. and more clay work.
  19. Zenator
    Zenator Minimodder
    12 May 2015
    This thing is big. Going to be fun adding it to the build, well the back of the build.
  20. Zenator
    Zenator Minimodder
    12 May 2015
    As a late surprise from TT with a Pacific DP-100 I'm going to still do what I can to mount it on the back of the case. And I think it will still do a top job keeping things looking clean and tidy. [​IMG]
    Also mounting it to the middle of the case still allows the use of the dust filter with the air being pulled in from the back.
    A test run of the logo. :(
    I say test run, Sadly the cold air got to it when printing and this one was no good. Building a old sever case up for the printer to go in at this moment to keep things warm. [​IMG]
    More on that soon.
