Case Mod - Complete ⭐ 2019 Thermaltake CaseMOD Invitational Season 2 - ZenModz Build log
Discussion in 'Project Logs' started by Zenator, 15 Sep 2019.
  1. Cheapskate
    13 May 2007
    Those d*mn things are too sensitive! :lol:
    Zenator likes this.
  2. Zenator
    Zenator Minimodder
    12 May 2015
    @Cheapskate. Yes they are. :)
    Clay ground & paint work is now done. [​IMG]
    censored_Prometheus_ likes this.
  3. Cheapskate
    13 May 2007
    ooh. It looks like exactly like rock now. I was scared for a bit. :D
    Zenator likes this.
  4. Zenator
    Zenator Minimodder
    12 May 2015
    Finishing off the control panel rock cover.
    next some paint and sealer.
    Adding the shading.
    And then the highlights.
    Old Thermaltake Fan Speed Controller K.n.o.b. Uncovered ! in the Dig.....
    So for the water cooling I have mounted the res on the back of the case, and running the tubing over the top.
    I made up a 6mm bracket to hold it all in place. The bracket is just cut out with hand tools and hand acrylic bender.
    Dose the job nicely I think. [​IMG]
    Thanks for stopping by.
    More again soon. [​IMG]
  5. Cheapskate
    13 May 2007
    The bender looks suspiciously like an '80s hair crimper.
    Zenator likes this.
  6. Zenator
    Zenator Minimodder
    12 May 2015
    Hello again. Been working on the lighting to find the best shadows, and all the RGB and power. And also adding some amber stones to the rock face. still working on some 3d prints.... And that is so slowwwwww. But all in all it is very close to being completed. [​IMG]
    logo time.
    And 15 hours and some paint. and it's done. :)
    Thanks again for stopping by, Hope you like what you see. [​IMG]
  7. Zenator
    Zenator Minimodder
    12 May 2015
    Final Photo's
    Hope you like it.
    Thanks for stopping by. :)
  8. Zenator
    Zenator Minimodder
    12 May 2015
    Dot_Kappa likes this.
  9. Cheapskate
    13 May 2007
    Very ..surreal build. :D New hardware looking like it was chipped out of stone. As always, you did fantastic work.
  10. Tech Cave
    Tech Cave What's a Dremel?
    18 Sep 2019
    Crazy idea and awesome realization! congrats!
