Modding 20pin need information on wire placement.
Discussion in 'Modding' started by copigeon, 12 Feb 2004.
  1. copigeon
    copigeon What's a Dremel?
    11 Jan 2004
    Need to find someone who has, or can see a cheiftec 340w psu...
    I did make a note of where all the wires went in the 20pin mobo connector before I started pulling pins, but it took a short trip into oblivion (mother + cleaning) and I’m a bit stumped for the wire placement (I also put tabs on the wires... labelled, by number as a back up, but I’m concerned that one of the wires doesn’t match every other psu I see, surely they should be standard?) ... I have a double orange wire... which goes in one of the three bottom slots... now, I have it on the second up on the non clip side, with 1 orange single wire below and 1 black single above.
    But the spare psu I have lying around and a friends has a double orange on the other side, at the same end right on the end with blue above.
    Can anyone confirm?
    Any help much appreciated.
  2. Xiachunyi
    Xiachunyi What's a Dremel?
    3 Nov 2003
    This should help you. Motherboard Power Connector
    Scroll a little ways down and you will find the ATX motherboard connector diagram.
  3. copigeon
    11 Jan 2004
    Thank you so much! Worries put to rest.
