Windows 2142 Demo - Initial Thoughts
Discussion in 'Gaming' started by Djpuk, 6 Oct 2006.
  1. Nath
    Nath Your appeal has already been filed.
    28 Dec 2003
    Redownloaded today and it worked fine, absolutely awesome game.
    Can't wait! :D
  2. SLICKMAN7667
    SLICKMAN7667 What's a Dremel?
    28 Sep 2006
    y the hate
    man theres way to much bad press for this game i only found out about bf2 from mi friend a month after it came out did that have this mnuch peopl slating it causs every where i go thers some one saying its rubbish gamespot xfire ign everywhere i love bf2 but i have to admit wher i first saw a vid for 2142 it did look simlar to bf2 just wid a new skin but isn't that just cuass they used same game engin
  3. Duste
    Duste Sierra my delta, bravo!
    1 Oct 2006
    Oh yeah, the game's pretty good, EXCEPT FOR THE GOD DAMN CRASH-TO-DESKTOPS. Seriously though, I get a crash-to-desktop within a minute of gameplay. I'm thinking it's no doubt my video card being below the minimum requirements, but I have no way of telling because they haven't released minimum requirements for Battlefield 2142 yet.
    HOWEVER! BF2 and BF2142 use the same engine, so I wouldn't imagine that the minimum requirements would have changed that much.
  4. Springs
    Springs Boing boing
    29 Aug 2004
    true true... i used to rock with that game...
    still d/l the demo...
  5. Krazeh
    Krazeh Minimodder
    12 Aug 2003
    Do you have a dual core processor? Don't know about the demo but the beta would crash out once you'd joined a server unless you set the the bf2142.exe process to only use one core.
  6. Neogumbercules
    Neogumbercules What's a Dremel?
    14 Aug 2004
    I keep getting stuck at "contacting EA Master Server."
  7. Nath
    28 Dec 2003
    C:\Program Files\Electronic Arts\Battlefield 2142 Demo\Support\readme.txt begs to differ.
    Might want to have a look over the readme (suitably named since you're supposed to read it.) before having a big old rant there. :eyebrow:
  8. Pygo
    Pygo Rick Relixed
    26 Jan 2003
    What?
    For the love of god, learn how to speak and write english. Likely it is your first language, otherwise I sincerely forgive you.
  9. keir
    keir S p i t F i r e
    5 Oct 2003
    ohhhhh lots of problems for you lot, the only problem I had was a direct X error, just needed to update it.
    the demo is alright the walker things are a bit daft tho.
    basicly BF2 with new guns/maps/vehicals
  10. atanum141
    22 Jul 2004
    Do people still play Vietnam? If so im gonna install it....
  11. babychaos
    babychaos What's a Dremel?
    12 Apr 2002
    Turn off any security software like Peer Guardian and firewalls.
  12. Rd52
    Rd52 Minimodder
    3 Jun 2005
    I liked it better than BF2, mostly because it runs better on my PC im running a P4 2.8 ghz, a 5200, and 512 of ram. also it takes less time to load than BF2 for me, the mechs were dissapointing, the hover tanks took a little to get used too. titan mode was great, conquest was boring in that map, overall i liked it, better than BF2 performance wise, everything else BF2 is better
  13. hitman012
    hitman012 Minimodder
    6 May 2005
    Fantastic fun :D (once I managed to get it working). Took some fiddling with router and DirectX to make it run, but it was worth the wait. If they fix the bugs and have a proper release that works, I'll be buying this.
  14. Springs
    Springs Boing boing
    29 Aug 2004
    as others had.. i had a problem with direct x.. not a bad game... take a while to get use to...
    i like titan mode... but i dont... it took ages to bring down via the reactor the titan once all the stuff was done... took like 5 of use with the rockets to do it...
  15. mookboy
    mookboy BRAAAAAAP
    15 Feb 2002
    You're talking about a DICE game here. They still haven't fixed all the problems with BF2 yet...
  16. Duste
    1 Oct 2006
    Oh? How do you do this?
  17. Veles
    Veles DUR HUR
    18 Nov 2005
    press ctrl+alt+del, click on the processes tab, find the bf2142.exe process, right click on it, then select set affinity, then untick one of the CPU cores, click ok and exit task manager.
  18. atanum141
    22 Jul 2004
    Im still crashing within the first 5mins, i setup my gfx to max and loading went smoothly but the game just crashes to desktop. I did have the DirectX issue and got the Dll file for it but it keeps bloody crashing.
  19. Noni
    Noni What's a Dremel?
    8 Dec 2005
    Have you got a Dual Core?
  20. atanum141
    22 Jul 2004
    Yah
    Ninja EDIT: U think i should set affinity?
