Windows 21H1 Update - News and Interest
Discussion in 'Software' started by Big Elf, 31 May 2021.
  1. Big Elf
    23 Apr 2009
    After the latest update to 21H1 a 'feature' called 'News and interests' is present on the Taskbar next to the Notification Area.
    Does anyone else have the problem that if you turn it off the Notification Area disappears until it's re-enabled?
  2. Big Elf
    23 Apr 2009
    Not 100% sure yet but this Registry edit might have fixed it.
    HKLM>Software>Policies>Microsoft>Windows then create a new key named Windows Feeds and add a new Dword(32 bit value) named EnableFeeds with a value of 0 followed by a reboot.
    EDIT: Sadly the Registry tweak didn't work either although it took a lot longer for the Notification Area to disappear. Looks like I'm stuck with the annoying icon until MS decided whether to bother fixing it.
    wyx087 likes this.
  3. sandys
    sandys Multimodder
    26 Mar 2006
    Not had that but my toolbars have moved to a fixed location which I don't like and can't change, which is odd.
  4. Big Elf
    23 Apr 2009
    I wonder if it's related. The default setting of News and interests takes up a lot of taskbar space so it might be 'crowding out' other items.
    I still use Quick Launch and that wasn't affected even though it takes up a lot of space on my double height taskbar.
  5. sandys
    sandys Multimodder
    26 Mar 2006
    Just had the update on one of my other machines and now have a fixed weather widget in that area that I can't disable....
  6. Big Elf
    23 Apr 2009
    I've done a couple of things that help although there's still wasted space on the Taskbar.
    Firstly I disabled all the options apart from News as you can't disable that and selected 'Show icon only' and 'Reduce taskbar updates'.
    Secondly I gave feedback to Microsoft and told them it's sh**.
  7. enbydee
    enbydee Minimodder
    10 Jul 2014
    If you right click on it one of the options is news or something and you can hide it. It wasn't immediately obvious to me either.
  8. wyx087
    15 Aug 2007
    Does this not work?
    (just upgraded)
  9. Big Elf
    23 Apr 2009
    In 3 of my systems if you turn it off the Notification area disappears until you re-enable it (see first post). It doesn't disappear immediately though, it takes a few minutes/hours.
    wyx087 likes this.
  10. sandys
    sandys Multimodder
    26 Mar 2006
    It did on the new system but the menu wasn't on my main system, so thinking about what is different I discovered what the issue was.
    My taskbar is set to top of the screen and in that location the news and weather doesn't show but it does leave space for it on the taskbar which is what pushed my toolbars along, there is no menu Item for news and weather etc so I can't do anything about it.
    Once I moved my taskbar to the Original location the news and weather bit now pops up at which point I could disable it then I could put the taskbar back on top autohiding and looking as it always had done.
    So all is right with the world again :) so if you taskbar is elswhere this could be why you are having issues.
    wyx087 likes this.
  11. thewelshbrummie
    thewelshbrummie Minimodder
    29 Aug 2009
    This might help. Apparently it's a known bug that Microsoft are aware of.
    Not sure I buy this as I still have the issue on my laptop despite uninstalling the update. Also, my gaming rig and stick PC don't have this problem regardless of whether the weather icon is visible or not.
