Displays 23"-24" display for ~£250
Discussion in 'Hardware' started by Daedelus, 8 Jun 2009.
  1. Daedelus
    Daedelus What's a Dremel?
    7 May 2009
    I need to finally upgrade my display (from a 17" CRT). I can't remember the exact video card I have but I think it's a GeForce 6800XT (it has VGA and HDI outputs). It will be used for some gaming (nothing hardcore) and watching DVDs.
    £300 is my very highest price, I preferably want it to be less.
    It also needs to be able to fit to a desk mount like this one, for example.
    I was looking at something like this one
    But I'll be honest, I don't really know what I'm looking for. It says it has a 1000:1 contrast ratio. Is that good, bad or indifferent? This did not really help.
  2. rickysio
    rickysio N900 | HJE900
    6 Jun 2009
    Contrast ratios are the same as unicorns.
    Although honestly, I'd advice you to get at least a PVA or IPS screen.
  3. Daedelus
    7 May 2009
    OK thanks
  4. azrael-
    azrael- I'm special...
    18 May 2008
    If you can live with 1680x1050 then the Dell 2209WA is for you (good price at OcUK). If you crave a higher resolution then have a look at the Samsung F2380 (23"@ 1920x1080). Otherwise, wait for LGs Wxx20 series coming in July.
    The Samsung comes with a PVA panel, the Dell and the LGs come with IPS panels.
  5. numanoid
    numanoid Minimodder
    26 Apr 2009
    ive just bought this m8, best buy ive made so far :D, you can pick free delivery lol
    http://www.ebuyer.com/product/158704
    take care
    sorry i didn't notice you wanted up to 24"
