Displays 24 inch monitor recommendation!
Discussion in 'Hardware' started by kaxliysi, 7 May 2013.
  1. kaxliysi
    kaxliysi What's a Dremel?
    8 Mar 2010
  2. docodine
    docodine killed a guy once
    10 Feb 2007
    i'd recommend finding a 1920x1200 monitor for that size
    1920x1080 looks better at like 21"
  3. GoodBytes
    20 Jan 2007
    Get a 23inch for that resolution. At 24inch, things will look a bit strange. Usually 24inch is for 1920x1200, as mentioned by docodine.
  4. smc8788
    smc8788 Multimodder
    23 Apr 2009
    Huh? Why would an extra inch make any difference in terms of how 'strange' it looks? Just because 1080p res is more common on 23" displays than 24" displays and 1200p monitors have traditionally been 24" doesn't mean that always has to be the case. Bigger is almost always better until you get to about 27" IMO anyway, so go with 24" if you can.
    Personally, while it's initially noticeable I find I got used to 1920x1080 on a 24" screen pretty quick and it doesn't bother me at all now.
  5. LordLuciendar
    LordLuciendar meh.
    16 Sep 2007
    Might not be as relevant to you, but I am very happy with my 3 Acer 24in B243PWL monitors which are 1920x1200 and have entry level 6 bit IPS panels. Looks like it's a bit more expensive than your price range, but I'm not horribly familiar with UK resellers and I really couldn't find it so it might be worth looking.
  6. chris182
    chris182 What's a Dremel?
    6 May 2011
    For me it's all about the Dell U2412M. Currently running 2 of those, and looking at getting a 3rd. As someone who does a lot of video editing and animation. That extra bit of vertical resolution makes so much difference!!
