Displays 24" or bigger monitor for <£250
Discussion in 'Hardware' started by sZCZ3p, 22 Jan 2013.
  1. sZCZ3p
    sZCZ3p What's a Dremel?
    9 Jul 2009
    I'm in the market for at least a 24" monitor to use as an external display for my laptop. I have roughly a £250 budget. I'd mainly use it for programming with some occasional gaming/movie watching. Hoping for an ips panel with at least 1080p resolution.
    My laptop is a Dell L702x with both hdmi and display port.
    Any suggestion would be really welcome
  2. Yslen
    Yslen Lord of the Twenty-Seventh Circle
    3 Mar 2010
    There are some Viewsonic 27'' IPS models for about 200 though they are only 1080p. Otherwise, Dell 24'' 1920x1200 or 1920x1080 IPS models are both around 200-220. If you're willing to step down to something a fraction smaller (23'') you're looking at 120-160 quid depending on brand. LG and viewsonic do great budget options. Nasty stand on the LG but a good panel at a bargain price.
  3. sZCZ3p
    9 Jul 2009
    I wouldn't mind a 23" if I can get a good and cheap one. Are there any sub £250 ones that are 1920x1200?
  4. GeorgeStorm
    16 Dec 2008
    U2412M is your best bet I reckon :)
  5. Yslen
    3 Mar 2010
    The Dell U2412 is the only 1920x1200 screen I know of.... there might be some others, of course.
  6. sZCZ3p
    9 Jul 2009
    Any specific models? I might be temted to go dual display at that price
  7. NRG IT - Olly
    NRG IT - Olly What's a Dremel?
    6 Dec 2012
    We're doing the Dell S2740L for £249 at www.nrgit.com. IPS panel with a resolution of 1920x1080 ;)
  8. Yslen
    3 Mar 2010
    sZCZ3p likes this.
  9. sZCZ3p
    9 Jul 2009
    Thx for all the replies. As much as I would love to get dell u2711 I'll settle for now for that Lg display.
  10. PhoenixTank
    PhoenixTank From The Ashes
    5 May 2010
  11. deant94
    deant94 What's a Dremel?
    14 Jan 2013
    BenQ have a great selection. Play.com sells a lot of 24+ inch monitors at very reasonable prices... plus free shipping :)
