Graphics $250.00 What gpu to get
Discussion in 'Hardware' started by grritsshawn, 10 Jul 2010.
  1. grritsshawn
    grritsshawn I'm not insane I'm a modder
    20 Apr 2009
    Okay well i don't care about the dx11 crud and stuff because most of my games i own are dx10.
    I have 250 max that shipped to spend on a new gpu. I will do crossfirex or sli.
    One thing i was thinking of doing was cf 5750? or 4870s?
    What do you think would be the best gpu solution and i game at a res of 1240x1080 i believe it is
  2. PocketDemon
    PocketDemon What's a Dremel?
    3 Jul 2010
    Assuming your stated res is kind of accurate, it is, comparatively, very low (& there's the issue that not all games can use CF effectively or, indeed, at all), you're going to gain very little by having 2 gfx cards - other than using more electricity/generating more heat.
    Now, that's not to say that, with a higher res monitor, 2x4870s in CF won't be somewhat more powerful than 2x5750 (if the game supports CF of course), which in turn is slightly more powerful than the 5850 (which obviously doesn't need the game to support CF as it's a single card, but appears to be above your US$250 by about US$40 new - though i've only checked NewEgg)...
    ...however looking at consistent fps in games (again the CF issue), running costs (since it would use less electricity) & in the ability to upgrade 'if' you bought a better monitor at some point (since you're only using one 16x pcie slot - 'if' you ever needed it, adding a 2nd 5850 when prices are more favourable would be significantly faster than 2x4870s), imho the 5850 would be the better choice atm given your set-up.
  3. docodine
    docodine killed a guy once
    10 Feb 2007
    Can you stretch to a 5850?
  4. Slizza
    Slizza beautiful to demons
    23 Apr 2009
    Would wait a couple days and see how the GTX460 is performing.
  5. Cerberus90
    Cerberus90 Car Spannerer
    23 Apr 2009
    He's already broken one 5850 somehow.
    This is about the third thread he's posted about graphics cards and they've all been pretty similar.
  6. shoxicwaste
    shoxicwaste Minimodder
    2 Jul 2010
    get 2 GTS 250's in SLI :3
  7. docodine
    10 Feb 2007
    Oh lol, I just read his previous threads.
    You should still get a 5850, just because your Powercolor broke doesn't mean that there is anything wrong with other 5850s.
  8. chrisb2e9
    chrisb2e9 Dont do that...
    18 Jun 2007
