Overclocking 2500k @ 5.0GHz 1.376v (1.368v load)
Discussion in 'Hardware' started by Lord Xeb, 8 Nov 2011.
  1. Lord Xeb
    Lord Xeb Derka Derpa Derka Derp
    7 Jan 2010
  2. Blogins
    Blogins Panda have Guns
    3 Aug 2010
    What sort of temperatures are you getting under Prime95?
  3. Guest-16
    Guest-16 Guest
    You enjoying the Pro, Xeb? :D
    Push that base clock up 1MHz, nude it over the 5Gs!
    Are you OCing via UEFI or AI Suite II?
  4. snooky32
    snooky32 What's a Dremel?
    29 Apr 2010
    Sounds like you bagged yourself a great chip there, mine just doesnt want to know over 4.5ghz at similar voltages :(.
    Would be very interested to know what your temps are like with the H100.
  5. bulldogjeff
    2 Mar 2010
    Nude it over 5G's..Are you seriously wanting Xeb to do his overclocking in the buff Bindi...lol
  6. YEHBABY
    YEHBABY RIP Tel
    22 May 2010
    You have an excellent chip there.
    Mines a bit of a dud. It needs 1.42v to run at 4.6Ghz.
    I had to up the volts to 1.48v to get it to run at 4.7Ghz.
  7. Guest-16
    Guest-16 Guest
    1.4+V - I'm assuming it's hot in his room!!
    :worried: :worried: :worried:
  8. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    wow sick.. 66% oc.. one more 6 in there and you got it =]
  9. Lord Xeb
    7 Jan 2010
    I hit 5.2 stable with 1.4 something volts.
    I don't even go above 70C
    Thanks
    Nope, only 70F in here
    Um... you suck at math. 51% overclock.
  10. kenco_uk
    28 Nov 2003
    Nice o/c Xeb!
    When I first got mine setup I went crazy with the o/c and managed 5Ghz @ 1.4something straight off the bat although the temperatures were very bad - I don't think the tim had cured as it went over 90c.
    Just tonight I updated the bios to 0902 from 0606 through the Ai Suite and I forgot to note the bios settings for the 4.5Ghz o/c (****ing doh :/ ). After a bit of tinkering, it seems to be stable at 4.6 @ 1.335v set in bios. CPU temp is 26c at idle.
    Apparently, I've saved over 1700mg of co2 emissions.
  11. jakobfrimmel
    jakobfrimmel What's a Dremel?
    2 Jan 2011
    HAHAHHAHA :clap: howd you work that out???
  12. Hazda
    Hazda What's a Dremel?
    7 Nov 2011
    Extremely jealous of your chip, good job.
  13. Lord Xeb
    7 Jan 2010
    Yeah I am still rocking the 05xx series bios on my board and don't plan on updating as I have no need ATM.
  14. thehippoz
    19 Dec 2008
    :D divided the wrong way- blame the calculator!
    you did that on a h100? probably the board too- some good ocing there either way
  15. LennyRhys
    LennyRhys Fan Fan
    16 May 2011
    What you using to test stability - got any screens of LinX or Prime etc?
  16. meandmymouth
    meandmymouth Multimodder
    15 Sep 2009
    Nice OC! I thought I had a good chip. Mine hits 4.8GHz on 1.352V and I'm happy to run that 24/7 (I think I might be able to bring the voltage down a tad).
    It needs 1.45V to hit 5GHz and stay stable, though.
  17. thehippoz
    19 Dec 2008
    yeah that's the thing.. assuming he means 24/7 stable.. I've been running a 48% oc for well over a year now with clarksdale
    seems that where intel chips are binned anyway.. around 50% of their stable running speed.. pretty generous even considering the server market.. gotta love intel :D
    I think that asus board he's running might have something to do with it too.. maybe a little more juice on the vdroop than others.. or it could just be an amazing chip or a combination
  18. OversizeZantos
    OversizeZantos What's a Dremel?
    12 Sep 2011
    nice oc, i'm at 4.5 with 1.32 and all the pll stuff on extreme, but had 5.1 @ 1.45 with a load temp of 82, so dialed it back as I've only got a 17 quid arctic cooling 13. my carbide 500r has room at the top for a h100 so when the missus isn't looking might order one and see how it goes
  19. knuck
    knuck Hate your face
    25 Jan 2002
    canard PC ? Are you french ? I never would have thought this site had survived the years !
  20. Lord Xeb
    7 Jan 2010
    I can get stable at 1.352v load with prime, but cannot pass linX, though if I bump it up 2 notches, I get LinX (AVX repack) AND prime stable. I do a minimum of 12 hours blend on Prime95.
    I think I should post my 4.8 stable overclock. I am stable at 1.312v load prime95 and LinX
    I have been folding for the past 3 days on this bad boy with no issues.... other than damn windows updates causing my PC to restart e-e
    IDK if anything is special about my board though. I am runing the 0508 bios on them.
    If I can pass folding, playing EVE (3 instances), AND watching a bluray, I think I am stable (BTW, all at the same time)
    >.> I run my H100 with 2 UK3K at 7v and never top out over 70C >.>
    Yeah my thoughts exactly.
