CPU 2500k staying at OC speed constantly
Discussion in 'Hardware' started by Neilc, 30 Apr 2011.
  1. Neilc
    Neilc Member
    5 Apr 2011
    Guys,
    Is this right - my cpu is staying at 4.6 all the time - I have only changed the multiplier and nothing else. If I boot using the default setting on the MB it drops down to 1600 when idle! is this normal?
  2. frontline
    frontline Punish Your Machine
    24 Jun 2007
    Is Intel Speedstep enabled in the bios?
  3. Neilc
    Neilc Member
    5 Apr 2011
    Yes its on, I hope this isn't a hardware fault!
  4. Sentinel-R1
    Sentinel-R1 Chaircrew
    13 Oct 2010
    Turn off the intel speedstep and C1E states etc in the bios and your CPU won't throttle back to power saving mode. :)
  5. frontline
    24 Jun 2007
    I think that is the problem, it isn't reducing the multiplier when overclocked and idle, but does when running at the stock multiplier.
    My i7 does drop down to around 1600Mhz when idle.
  6. Neilc
    Neilc Member
    5 Apr 2011
    Still really confused as all is the same as default - unless a parameter changes when you change the multiplier to manual setting?
  7. GoodBytes
    20 Jan 2007
    is Windows Power scheme set to Balance?
    When you say SpeedStep is On, is really set to "Enable" or "Auto". If you have the choice between both, select "Enable", same for C1E.
    thehippoz likes this.
  8. Neilc
    Neilc Member
    5 Apr 2011
    Ahh no set to performance - that would explain it - cheers buddy
  9. frontline
    24 Jun 2007
    Hmm, am sure mine is set to performance too but Speedstep still adjusts the CPU multiplier when idle.
  10. Neilc
    Neilc Member
    5 Apr 2011
    Cheers buddy - all sorted - everything was set to enabled except C1E which was on Auto.
  11. thehippoz
    thehippoz New Member
    19 Dec 2008
    like goodbytes needs any more rep.. the only thing to look out for neil is sometimes the jump in speeds will cause instability
  12. Guest-16
    Guest-16 Guest
    Windows 7 overrides it.
    Under the CPU options in the Power Management it has a setting that changes processor speed like Speedstep.
    Good call, GoodBytes!
    If you get instability then you can just tweak the DIGI+ VRM settings - push the frequency to Extreme so the response is faster, and turn it TProbe to Extreme so the power comes from all VRMs equally and fully all the time. There's other settings too like Loadline calibration, but those should help.
  13. frontline
    24 Jun 2007
    Is it one of these settings that would override the bios setting?
  14. GoodBytes
    20 Jan 2007
    Yes. All 3 of the Processor power management items in the Advance Settings of the Power Options (System cooling, Maximum processor state, Minimum processor state)
    It is to be noted that the percentage set in Maximum/Minimum processor state is not exact values. It depends on what the CPU support. If the CPU support 30%, 50% and 100% (let's say), then Windows will pick the option that is the nearest to what you pick. In other words, setting the CPU at 0%, won't freeze your computer. Selecting 98% will most likely have your CPU still go at 100%
  15. Marine-RX179
    Marine-RX179 New Member
    24 May 2010
    Hm...how come my Windows 7 Home Edition only has "Systerm Cooling Policy" for Processor power management, but no Minimum and Maxium process state?
    On the sidenote..Neilc you are using above 1.4v vcore for the 4.6GHz overclock? I read that for SandyBridge CPUs if you run them at above 1.35-1.38v vcore, it will shorten the lift span of the CPU quite a bit...
    http://forums.overclockers.co.uk/showthread.php?t=18227651
  16. GoodBytes
    20 Jan 2007
    Because your processor doesn't support that feature.
    Vista/Win7 power management also provide support for drivers, so that additional drivers can add power options, like on my laptop I have these options:
    I can cut power to the optical drive, media card reader, firewire, and reduce the monitor refresh rate from 60Hz down to 40Hz, to reduce power consumption. This allows me to reach the 9hours and half of battery life with the 9-cell. Or 10 hours and half with my special software that is coming (GPU power control based on what you run).
  17. dave99
    dave99 New Member
    26 Jan 2011
    Our Goodbytes who art in heaven........or Canada.
  18. frontline
    24 Jun 2007
    Any reason why the minimum and maximum processor state set to 100% in 'High performance' mode still downclocks the CPU?
  19. Guest-16
    Guest-16 Guest
    Shouldn't do. Disable your power savings in the BIOS :p
  20. jimmyjj
    jimmyjj Member
    20 Jul 2010
    Heh,
    I had this exact problem the other day, took me ages to figure out it was windows power settings. I should have asked here...
