Build Advice 2500k upgrade to 4770k
Discussion in 'Hardware' started by Concrete-Coffin, 7 May 2017.
  1. Concrete-Coffin
    Concrete-Coffin Member
    5 Apr 2010
    just need a bit of advice to see if its worth it. I can get a 4770k and a msi z87-gd65 gaming mobo and a 128gb msata card for £140 as my 2500k still going ok in games etc
  2. David
    David Take my advice — I’m not using it.
    7 Apr 2009
    For that price, yes, go for it.
    The performance increase won't be huge but upgrading two generations for that price is worthwhile, plus you'll claw back at least half of it by selling your 2500K and mobo.
    Cheap upgrade.
  3. Concrete-Coffin
    5 Apr 2010
    Cheers David think all go for it then
  4. atc95
    atc95 I have the upgrade bug!
    3 Dec 2012
    A great price but upgrading to a platform that still doesn't have M.2 or DDR4 is a bit pointless imo.
  5. Concrete-Coffin
    5 Apr 2010
    i would of liked to go newer but funds at the moment for a full overhaul are limited and this would last a little longer
  6. David
    7 Apr 2009
    M.2 isn't all that big a deal - I've been running an NVMe SSD as my OS drive for over a year, and it's not noticeably faster than a decent quality SATA3 SSD; despite boasting 4x the read speed and over twice the write speed of any of my SSDs.
    Also DDR4 is fooking expensive right now, and the prices are set to either increase or plateau for the rest of the year - this upgrade won't require new RAM. From a value for money point of view, this is a no brainer.
    A Kaby upgrade will set the OP back £500, without m.2.
  7. silk186
    silk186 Derp
    1 Dec 2014
    not going DDR4 means he can reuse his DDR3, that reduces cost now. When he finally does move to DDR4 prices should have improved.
  8. TheMadDutchDude
    23 Aug 2013
    Bargain. You should jump on it! The CPU is worth the £140 on its own. :)
    NVMe can be used on Z87 with a bit of tweaking. It's not too difficult. I definitely notice the difference between my 850s and the SM951 when it comes to loading things. It doesn't have as big a difference between going from a HDD to an SSD, but the difference is still there.
  9. Concrete-Coffin
    5 Apr 2010
    just bought it from a m8 at work so hopefully have it up and running when get a chance to pull me pc apart thanks for the input lads
  10. Vault-Tec
    30 Aug 2015
    Yeah that's a great price. I saw loads of people go through Sandy/Ivy/Haswell etc. Very worthy upgrade IMO. Extra threads are always nice too :)
  11. Yadda
    Yadda Well-Known Member
    25 Jul 2003
    Will definitely keep you going for longer than your 2500k and a great price too.
    Bargain!
  12. Wakka
    Wakka Yo, eat this, ya?
    23 Feb 2017
    I can't figure out if it's a testament to how good the 2500K was, or how bad Intel have been at actually moving the performance post forward haha.
    My 2500K was the first CPU I've ever owned for more than 3 years (was actually close to 4), was a sad day to see her go...
  13. Concrete-Coffin
    5 Apr 2010
    Yeah been a great buy got it a few weeks after they fixed the sata problem on the boards so that's easy 4+ years ago
  14. bawjaws
    bawjaws Well-Known Member
    5 Dec 2010
    It's probably also an indictment on how games have stagnated in terms of CPU utilisation.
