Displays 2560 x 1440 Monitor
Discussion in 'Hardware' started by KD88, 7 Dec 2015.
  1. KD88
    KD88 Minimodder
    25 Aug 2009
    I've just bought a 27" monitor with a 2560 x 1440 resolution but when I go to change the display the adjuster only shows a maximum of 1920 x 1080.
    I'm running Windows 10.
  2. thom804
    thom804 Minimodder
    22 Oct 2009
    What graphics card are you running?
    Also, what is the monitor make and model?
  3. Vault-Tec
    30 Aug 2015
    If his sig is correct then a 6950...
  4. KD88
    KD88 Minimodder
    25 Aug 2009
    Yes 6950 and its an Aoc Q2778VQE
  5. thom804
    thom804 Minimodder
    22 Oct 2009
    ◾DisplayPort 1.2
    ◾Max resolution: 2560x1600 per display
    ◾Multi-Stream Transport
    ◾21.6 Gbps bandwidth
    ◾High bit-rate audio
    ◾HDMI® (With 3D, Deep Color and x.v.Color™)
    ◾Max resolution: 1920x1200
    ◾Dual-link DVI with HDCP
    ◾VGA
    ◾Max resolution: 2048x1536
  6. GuilleAcoustic
    GuilleAcoustic Ook ? Ook !
    26 Nov 2010
    What kind of cable did you use to connect the screen to the GPU ?
  7. Parge
    16 Jul 2010
    HDMI or DVI. Guarantee it.
  8. jinq-sea
    15 Oct 2012
    See. He really is the worst one. He's so unhelpful!
    Yes -almost guaranteed, it's a single-link DVI cable, or HDMI.
  9. Parge
    16 Jul 2010
    I can't help it. I'm incredibly, incredibly lazy. To the point where I qualify for a disabled parking badge.
  10. KD88
    KD88 Minimodder
    25 Aug 2009
    We're not all from the IT generation, calculators only just hit the market when I was studying for my O'levels, I got a new state of the art, new fangled and expensive digital watch for my eighteenth birthday, didn't use the word "computer" I guess before the age of 25 and bought my first PC when I was well into my 40's.
    What little I do know now about them has been self taught or by research and help from those who know a lot more than I do.
    Thanks for the helpful replies, I've sorted it by changing the HDMI cable for the DVI-D.
  11. Kovoet
    Kovoet What's a Dremel?
    26 Aug 2009
    Lol calculators weren't even out when I did mine
    Sent from my HTC One M9 using Tapatalk
