2560x1600 30 inch gaming monitor
Discussion in 'Hardware' started by Koda, 3 Sep 2013.
  1. Koda
    Koda What's a Dremel?
    27 Feb 2013
    Hello. I am in some serious help of finding a new monitor.
    The monitor must be a 30 inch. Not 27 or 24 but 30 inch! :)
    Resolution must also be 2560x1600.
    What shall I use this monitor for?
    FPS games mainly but also some RTS like SC2 and Diablo 3.
    So guys.. What can you recommend me? The price doesn't really matter. I just want a 30 inch monitor that can be used as a gaming monitor first and foremost.
    Thanks for your time reading this.
    Best regards
  2. Combatus
    16 Feb 2009
    I've moved this to the hardware forum as you're more likely to get a response here!
  3. Nexxo
    Nexxo Rotate Your Owl For Science
    23 Oct 2001
    Dell WFP3007-HC. If you can still get one...
  4. Shirty
    18 Apr 1982
    Combatus: can still move threads even without a red name...
  5. docodine
    docodine killed a guy once
    10 Feb 2007
    from what i've read the dell U3014 has the lowest input lag of the 30 inchers when set to 'game mode'
  6. Pookeyhead
    30 Jan 2004
    They just aren't built with that in mind, so they're all not a first choice for gaming only, but if you want big, and you want 1600, then the 3014 seems a good call, and Nexxo's suggestion of a used 3007 would be another... I'd go with either of those two.
  7. GoodBytes
    20 Jan 2007
    Assuming you want new. Del U3014, is the only 30inch monitor (you have only a handful really.. so that is why.. (small market)), would be the best for gaming and workspace.
  8. djzic
    djzic Bokehlicious!
    8 Nov 2010
    The 3014 is 16:9 which means 2560x1440, not 2560x1600...
  9. GoodBytes
    20 Jan 2007
  10. djzic
    djzic Bokehlicious!
    8 Nov 2010
    Whoops :blush:
  11. Guest-16
    Guest-16 Guest
  12. docodine
    10 Feb 2007
    asus should throw in a GTX titan with that monitor
  13. Elton
    23 Jan 2009
    So, the LP3065 is also a choice, as is the ZR30W.
    The 3007WFP, I would recommend the non HC one just because wide gamut can be a pain in the ass if you don't have color profiled apps.
    There are actually quite a few options but those are the ones I can remember. The 305T is a decent option if you don't mind the S-PVA, but the LP3065, the U3011, the 3007WFP are the most obvious choices.
    And the NEC 3090WQXi of course.
  14. Guest-16
    Guest-16 Guest
    If you can afford that monitor you can afford a Titan ;)
  15. damien c
    damien c Mad FPS Gamer
    31 Aug 2010
    For the price of that monitor you could easily build a high end pc and import a 4K TV from America.
    I will wait for the price of the monitors to actually be realistic before I buy one, but the Asus one does look like a decent monitor.
  16. docodine
    10 Feb 2007
    the tv you're talking about can only do 4K at 30Hz
  17. Guest-16
    Guest-16 Guest
    You really have to watch the spec of 4K panels, people are cutting corners on the cheap stuff.
  18. David
    7 Apr 2009
    Yes, 30 inches of Dell awesomeness - heartily recommended! :D
  19. Shirty
    18 Apr 1982
    Remind us how much yours cost Dave :grr:
  20. David
    7 Apr 2009
    It was hugely expensive!
    Approx £50 :D
    Dude, what's with the leotard? You're freaking me out!
