Displays 27 Inch Monitor
Discussion in 'Hardware' started by Furore, 22 Sep 2011.
  1. GoodBytes
    20 Jan 2007
    Ahhhhh!!! Much clearer now.
    Thanks.
  2. wyx087
    15 Aug 2007
    i'll be honest, 2560x1440 isn't that great for general work. i have to sit forward to read text in steam chat, or any text that is displayed at normal size.
  3. GoodBytes
    20 Jan 2007
    Yes, it's a bit small at 27inch.. it's a bit like 22inch at 1920x1080, but you can increase DPI settings. Everything will be bigger, but smoother like on the picture above. Or simply increase font size. Just small ideas on how help out your setup.
  4. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    Yes
  5. Furore
    Furore What's a Dremel?
    22 Sep 2011
    Thanks for the input everyone, I appreciate it.
  6. longweight
    7 May 2011
    It's amazing working at that res! If you have to squint at it when sat at a desk then you might need glasses....
  7. wyx087
    15 Aug 2007
    i do need glasses, just take them off when im at home. what's your point :p
  8. SirFur
    SirFur PC Gamer and LAzy B0nes
    8 Apr 2009
    LOL
    I think going for a proper 27" with the 2560x1440 resolution would mean I'd have to fork out an extra £150 for a GPU that would be able to handle it properly in games. Hence, I'd rather settle for a smaller screen, and perhaps add a second monitor for dual work and play purposes...playing games in 3-way monitors would still require a beefy GPU with 3GP...but something I can decide down the line.
  9. Furore
    22 Sep 2011
    I have been basing all my computer build and research for everything off the fact that I play most of my games at 1920x1080. If the Dell Ultrasharp is the best thing going, then I see no reason to get a bigger screen. I will probably just buy another one in the immediate future to multitask.
    Separate question, my build includes a GTX 570 1.3GB SC (I am basically taking the bit-tech gaming build with a few storage mods). Do I need to run dual/triple SLI to get maximum performance from two monitors? Keep in mind I wont be dual screen gaming anytime soon.
