Graphics 290 unlocked to 290x
Discussion in 'Hardware' started by jizwizard, 15 Nov 2013.
  1. jizwizard
    jizwizard Modder
    24 Dec 2010
  2. Parge
    16 Jul 2010
  3. Neogumbercules
    Neogumbercules What's a Dremel?
    14 Aug 2004
    That would be pretty awesome...
  4. Gnemelf
    Gnemelf Minimodder
    9 Aug 2003
    It can be done... but time will tell if the pcb's can handle it... I suppose with enough cooling it'll be fine..
  5. Sheiken
    Sheiken Wat?
    9 Jan 2005
    To my knowledge the PCBs are exactly the same? And so is the TDP, so it should be a non issue.
  6. Parge
    16 Jul 2010
    So apparently it is true.....
  7. Blogins
    Blogins Panda have Guns
    3 Aug 2010
  8. kirk46
    kirk46 Cheesecake Nom Nom
    9 Jun 2012
  9. heir flick
    heir flick Minimodder
    2 Feb 2007
    Orderd from ocuk, should be here monday
  10. Blogins
    3 Aug 2010
  11. Sheiken
    Sheiken Wat?
    9 Jan 2005
    I checked if my Sapphire 290 was unlockable yesterday, and I wasn't even disappointed by the fact that mine isn't.
    It still performs wonderfully and I can't remember ever being so satisfied with a graphics card purchase.
  12. AlienwareAndy
    AlienwareAndy What's a Dremel?
    7 Dec 2009
    That's the best attitude to take really. I've bought supposedly amazing things that are not amazing until you overclock them (and then you need luck). My Allendale Core 2 was clocked to 1.8ghz out of the box and could supposedly do 3ghz. However, what I didn't realise was that in order to run it at 3ghz you needed a really expensive board with really expensive memory (DDR2 clocked to 1066) which by the time you were done was no cheaper than buying the Core 2 that was nearly 3ghz any way.
    With the 290 to 290X you're not really gaining much any way given how brilliant the 290 is.
  13. Blogins
    3 Aug 2010
    Sapphire supposedly released an enhanced BIOS...
    http://www.sapphiretech.com/presentation/media/?psn=0004&articleID=5453
    Not that I can find it anywhere! :rolleyes:
  14. phoenixck
    phoenixck What's a Dremel?
    7 Jan 2012
    Most of the really early release cards can, it seems though that AMD have already actually changed the manufacturing process slightly so any after the first batch don't actually have the required parts on the silicon to flash the bios to a 290x.
  15. adamg64
    adamg64 What's a Dremel?
    19 Jul 2010
  16. heir flick
    2 Feb 2007
    got my unlocked 290 from ocuk for £359 so yep i would cancel
    from what ive read the best ones to unlock seem to be his,xfx and vtx3d
  17. Blogins
    3 Aug 2010
    At this point with only 1 in stock from Overclockers I'd stick with dabs.
    With postage you'll only be saving a tenner since Overclockers raised the price.
