Graphics 2ghz 680??
Discussion in 'Hardware' started by feathers, 27 Mar 2012.
  1. feathers
    feathers Minimodder
    11 Apr 2009
  2. Parge
    16 Jul 2010
    I call BS. They've only managed to get it to 1.8Ghz under LN2.
  3. thetrashcanman
    thetrashcanman Angel headed hipsters
    18 Nov 2010
    2Ghz? Behave!
  4. The_Crapman
    The_Crapman Don't phone it's just for fun. Staff
    5 Dec 2011
    Details of PoV's ultra charged and watercooled beast should be released later this week. Apparantly all 3rd party pre-overclocked 680's have to be approved by nvidia and I can't see them allowing that if it were even possible. Which it's not. :nono:
  5. Guest-44432
    Guest-44432 Guest
    They may have missed the '1.' in front of the 2, so maybe a 1.2Ghz GTX 680, which would be more realistic, and a great OC if it were to be true.:)
  6. feathers
    feathers Minimodder
    11 Apr 2009
    Unlike some of the impetuous clowns here, I will not be rushing out and buying 2 x 680 2gb.
    I intend to sit and wait for the 2ghz 8gb version.
  7. jakobfrimmel
    jakobfrimmel What's a Dremel?
    2 Jan 2011
    well there will be a 4gb version....
    but a 2ghz 8gb version... well common.. you honestly think thats gonna happen?! really?! 0.o
  8. Marvin-HHGTTG
    Marvin-HHGTTG CTRL + SHIFT + ESC
    10 Oct 2010
    I do believe he is somewhat taking the piss. :D:thumb:
    I'd have to agree with others here, someone mis-typed or mis-heard or something about this card, as 2GHz just isn't going to be possible. 1.8GHz on LN2. Zotac would need a monster of a cooler for starters. Not to mention that at some point, the chip will no longer be stable, no matter how much voltage and cooling you throw at it. So yeah, 1.2GHz with turbo on sounds more realistic to me.
  9. jizwizard
    jizwizard Modder
    24 Dec 2010
    From what I heard they are cherry picked to hit 2ghz on ln2. Not 2ghz standard.
  10. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    This seems the most logical explanation to me.
  11. feathers
    feathers Minimodder
    11 Apr 2009
    Gigabyte produced some excellent Super Overclocked cards using the cherry picking method and custom voltage design. I agree that the 2ghz is just nonsense especially from Zotac.
    Some people seem to be getting 170mhz on air with their 680 which I would say is very promising for future versions.
  12. Guest-44432
    Guest-44432 Guest
    I hope this is true...roll on august! GK110
  13. kenco_uk
    28 Nov 2003
    I'm waiting for one with an ssd in it as I've heard they're pretty fast.
  14. noizdaemon666
    15 Jun 2010
    Nah the SSD version is for those with older systems that can't keep up. They ripped out the vRAM and 256bit memory bus and replaced it with the slower SSD and SATA controller as it's cheaper than using the expensive memory and stuff. :p
  15. feathers
    feathers Minimodder
    11 Apr 2009
    OCZ vitality.
    They left out one of the $ for the GK110.
    There will be a budget version with 512mb and using system ram to make up the rest.
  16. .//TuNdRa
    .//TuNdRa Resident Bulldozer Guru
    12 Feb 2011
    I find myself wincing at just how much those new cards will cost. Nvidia was bitching about GlobalFoundaries cost per transistor, so 6 billion of them will cost an outright damn fortune!
  17. GoodBytes
    20 Jan 2007
    It is very possible... with the right cooler:
    (that is 3 PCI slot thick, plus the added heatsink on top) :D
    From iGame
  18. noizdaemon666
    15 Jun 2010
    Even with that extravagant cooler, I doubt 2000MHz core clock would be possible. The extreme cold of LN2 helps stability at such high clocks.
  19. feathers
    feathers Minimodder
    11 Apr 2009
    My 680 watt peltier cooled by 2c cooled liquid might help.
    And since I use pulse width modulation to vary the power to the TEC according to load, the system only hits 1.5kw when I play BF3 or crysis 2.
  20. thetrashcanman
    18 Nov 2010
    Ohhhhhhh hooooooooo ahhhhhhh, I think I just had a trouser accident, good GK 110 is what I want, not stupid GK 104
