Scratch Build – In Progress ::2in1:: Custom Aluminium/Plexi Dual PC Case Update #6
Discussion in 'Project Logs' started by CharlieCat, 11 Oct 2003.
  1. madhatter
    madhatter What's a Dremel?
    16 Sep 2003
    how are you gonna go about replacing a face?! hehe :D
    I'm impressed, nice to see something original rather than the standard paint, window and fan job. I love your server case too, and im glad to see i'm not the only mp3 freak (154gb)
  2. Fr0z3n
    Fr0z3n What's a Dremel?
    21 Oct 2003
    This looks so awesome so far. :D If only I could think up things so original. :sigh:
  3. CharlieCat
    CharlieCat What's a Dremel?
    12 May 2002
    Well I started work on the mounting for the two optical drives...but I think I may go a different route now as I think it's gonna look a bit too fussy. Here's what I did anyway...
    What I was planning was to stealth the two drives using the two small blanks and then insert them into the large hole with perspex behind which would be glowing.
    But as I said it all looked a bit too much...I'm not really a fan of stealthing anyway...I like to see wht I've spent my money on.
    Cheers, CC
  4. CharlieCat
    12 May 2002
    New Bits
    I also got some bits'n'bobs in the post.
    First up we have a second 400w silent Zalman PSU along with another Zalman silent CPU HSF plus two nexus fan controllers.
    The Nexus fan controllers have built-in dual CC inverters plus two blue cathodes.
    Really rather neat.
    Next up a box of finishing of bits.
    We have a couple of 120mm red LED fans and a single 80mm version. Some blowhole trim and some window molding plus some short single device IDE cables and some cable sleeving stuff which is UV reactive.
    Now for some more moddin....
    Cheers, CC
  5. FlashPanHunter
    FlashPanHunter What's a Dremel?
    22 Aug 2003
    Very nice cutting. Good call on the plexi, it might not be the best with the sort of industrial look, which by the way I am becoming very fond of. :thumb:
  6. CharlieCat
    12 May 2002
    Update #5 :: Mounting the VFD and Fan Controller
    Just to be a bit different I decided to mount the two fan controllers vertically. This will also make it easier to see that one is for each machine.
    So with it marked out...
    the holes got cut out using a 20mm holesaw and a 13mm drill bit. Then some filling and all was looking sweet.
    Next I started work on the two brackets which would hold the fan controllers in place. Firstly I cut a blank the correct size and marked a line where I wanted the bend to be. Then I clamped the piece in my vice using a couple of off-cuts of the metal tubing to extend it's grip.
    Then, using the hammer and the large piece of wood, I began to bend the metal slowly...working evenly along it's length.
    Nearly there....
    All done :D
    Two brackets, one for each side.
    Then using the same method....
    I made a mounting for one of the VFDs to be installed.
    More to come later...
    Cheers, CC
  7. CharlieCat
    12 May 2002
    Update #6 :: Progress Update
    A small update of how things are looking right now.
    This is the overall look at the moment. You can see that I've mounted the two fan controllers on the sloping section. I stall have to decide what to do with the rest of the space. I have a largish VFD to go there but that will still leave some space.
    I have also got the two optical drives installed. Hopefully there will be a blue glow around the edge of the cutout but I have not tried that out yet.
    I also fitted the front fan. I decided to mount it directly to the front panel instead of using the plexi mount as it helps keep the perpsex panel in the front secure.
    Here's a close up of the mounting bracket for one of the fan controllers.
    And a dodgy picture showing the VFD mounting in place.
    Here's two of the hard drives mounted. I have put them right in front on the intake fan to keep them nice'n'cool.
    The other PSU has been installed. It is the same 400w Zalman as the other PSU.
    Also, the two rear fans have been installed...
    Along with the Zalman HSF for the top PC...
    Which is very large indeed.
    Finally a shot in the dark showing the two fan controllers in all their glowing glory.
    Cheers, CC
  8. papeniglio
    papeniglio Minimodder
    5 Dec 2002
    :eeek: I love it!!!! :eeek:
    I agree with you about the not-stealthed optical drives: much better to see them!
    Go on, you rock!! :clap: :clap:
  9. ReFredzRate
    ReFredzRate Relix Headshot!!
    2 Sep 2002
    Oh man... I love the way this thing is taking shape... Coming very close to perfection! :clap:
  10. ouija
    ouija Trust me, I am doctor!
    10 Nov 2002
    Awsome! Taking shape nicely and it looks so cool. You love that chequerplate (sp) stuff don't you? :lol:
  11. keir
    keir S p i t F i r e
    5 Oct 2003
    wow thats a big computer(s) I like the way you turned the bottom mobo upside down, I think its daft the way case's are made (cpu and psu so close) for cooling freaks :D
  12. FlashPanHunter
    22 Aug 2003
    Holy crap that is nice! The wtx style is perfect for the lay out. Man its hilarious to see those drives just dwarfed in that massive beast. And quick updates too. What a great project :clap:
  13. Solarius
    Solarius What's a Dremel?
    3 Oct 2003
    Very solid. All your cuts are so professional!
  14. Atomic
    Atomic Gerwaff
    6 May 2002
    If only this was watercooled... It'd be a monster then...
  15. madhatter
    16 Sep 2003
    that IS a monster
  16. broots
    broots What's a Dremel?
    24 Sep 2003
    Should be enough space to watercool this thing.. Hmm would need two separate systems.. Anyway
    Looks better and better, keep up the good :dremel:
  17. Atomic
    Atomic Gerwaff
    6 May 2002
    So wrong!!! Nah, just a double rad x2 and big enough pumps in series... sorted!
  18. Solarius
    3 Oct 2003
    Hell you could probably just build a refigeration unit into one side. :) Wouldn't increase the footprint that much. :) You'd need a dehumidifier or something too prolly. :brrr:
  19. broots
    24 Sep 2003
    m'bad.. would need two of something to keep it properly cooled, right?! ;)
    Two rads, one water system, or two separate systems, wouldn't be much difference, would it?
    [edit]But that's a whole different discussion.. [/edit]
  20. Fluba
    Fluba What's a Dremel?
    20 Jun 2003
    whoa... this things about 10x better than anything ZapWizards ever done xD
    great looker, lots of work gone in... like it
