Scratch Build – In Progress ::2in1:: Custom Aluminium/Plexi Dual PC Case Update #6
Discussion in 'Project Logs' started by CharlieCat, 11 Oct 2003.
  1. Dark_Blender
    Dark_Blender What's a Dremel?
    3 Jan 2003
    Turned out pretty sweet man. You should keep going. Its way sexy :rock:
  2. ModCanada
    ModCanada What's a Dremel?
    24 Sep 2003
    Yes very very nice. Good work.
  3. andrew
    andrew What's a Dremel?
    11 Aug 2003
    is that front piece of plexi going to be coloured? or replaced with metal as I think it would look beter that way. It's turning out really nice.
    How about some stealthed front ports in that gap.
  4. Lithium
    Lithium super spunk
    26 Jul 2002
    Been keeping a eye on this and must say that you made a hellava nice case...really like it :thumb:
    As andrew said, may look better if the plexi was tinted.
  5. CharlieCat
    CharlieCat What's a Dremel?
    12 May 2002
    Thanks for your comments :D
    I will be tinting all of the plexi using some Dark Smoke window tinting film.
    Hopefully you will not be able to see in when the lighting is off but be able to see all when on. I will also be using some aluminium mesh on the front panel and intake fan.
    But I want to replace the plexi first with thicker stuff to allow for some LED lighting to be employed. At the mo it's only 2mm so I think I'll use some 5mm which is the thickist I can find locally.
    As for water cooling...it's something I've never tried. I do not plan on overclocking either of the machines and those large Zalman HSF are pretty damn quiet...so much so that the loudest components are the hard drives. Maybe something to think about for a future update. As said there is plenty of room in the case.
    More to come in the next day or two.
    Cheers, CC
  6. burntloser
    burntloser What's a Dremel?
    28 Oct 2003
    wow. this thing is amazing.
  7. Lithium
    Lithium super spunk
    26 Jul 2002
    yodasarmpit used some black window tint from Halfords when doing Project -::Y::-. Seen his case in the flesh and when the cathodes are on ya can see inside and darkness when off. Nice effect.
  8. auspex
    auspex What's a Dremel?
    27 Oct 2003
    :jawdrop:
    ^says it all! nice work man.
  9. ramapoughnative
    ramapoughnative What's a Dremel?
    26 Sep 2003
    Great metal work!! :rock:
  10. STellY
    STellY What's a Dremel?
    24 Aug 2003
    been following intently just wanted to chirp in and say it looks AWESOME... keep up the good work this is sure to be one hell of a finished product :)
  11. Confusitron
    Confusitron What's a Dremel?
    22 Dec 2002
    This project is one delicious piece of goodness pie!
  12. Lisdexia
    Lisdexia What's a Dremel?
    27 Oct 2003
    CharlieCat, have you thought about making some HD enclosures out of aluminum and/or plexi? that can cut down on HD noise quite a bit. thats what i plan on doing later on from a milled out 2" 7x7 piece of T6.
    anyways, love the progress so far. :D
  13. Foolio882
    Foolio882 What's a Dremel?
    1 Sep 2003
    Lookin great man! Very nice work!
  14. Bluebark
    Bluebark What's a Dremel?
    1 Sep 2003
    Smok’n setup Bro…I love the diamond plate, takes me back to my younger days in the body shop. You just have to put wheels on this thing. Maybe some small industrials…you know the kind, spring loaded in the back with locks on the side. You could put stationeries in the back and swivels up front. It took me 45min to read though this thread...and worth every minute of it.
    You :rock:
  15. DrSpYdeR
    DrSpYdeR What's a Dremel?
    28 Oct 2003
    Another great creation.. :clap:
  16. Pistol
    Pistol Guest
    I love the aluminum, I've been trying to find out what the stuff is called. What is it, how much did you pay, and where might i find it? (if its not too much trouble :hehe: )
    Seriously, awesome work. Perhaps you could create a designed face plate that the optical drives mount to that fits with the whole theme, but doesnt look too out of place in the middle of the case... and are you planning a HDD rack from the aluminum? I might have missed if you said so, but I think it's only fitting that it should match.
    Precision work man, truly.
  17. korhojoa
    korhojoa durr
    31 Oct 2003
    i just gotta say that your case rocks!
    you should put a small lcd screen up there in the middle of the fanbuses, you could have a switch to choose between server / multimedia comp, cool eh?
  18. Lord Kordir
    Lord Kordir What's a Dremel?
    5 Nov 2003
    After reading this thread (ie. checking out the pics!) I had just had to bump it to the top. Can't wait to see more pics!
  19. A13n0rma1
    A13n0rma1 Wannabe
    17 Jul 2003
    Instead of a VFD, why don't you pick up a small-ish LCD monitor?
    The best buy around here is selling a 14" one cheap.
  20. Krycek1
    Krycek1 What's a Dremel?
    28 Sep 2003
    Wow, very impressive. I love that TV too, Give us some picks of that baby in action. Its hooked up to the computer too right?
