Motors 2nd Battery
Discussion in 'General' started by A13n0rma1, 31 Dec 2004.
  1. A13n0rma1
    A13n0rma1 Wannabe
    17 Jul 2003
    Say I wired a 2nd battery to my car in parrallel.
    ...would it do anything different? What are the effects? Anything?
  2. BioSniper
    BioSniper Minimodder
    5 Feb 2002
    you may need a better alternator as the extra charge strain could kill your existing I would guess
  3. xen0morph
    xen0morph Bargain wine connoisseur
    30 Jun 2002
    You'd be able to pull more current, so in theory you'd have better cold starting.
    But yeah, you would probably need to upgrade the alternator.
  4. :: Phat ::
    :: Phat :: Oooh shakalaka!
    7 Jun 2002
    I'm sure theres something wrong in the design, which is why audio entheusiasts use a split charge system.
  5. h4r7y
    h4r7y What's a Dremel?
    9 Oct 2004
    thought of a power cap?
    if its being used for stereo eqpt etc?
  6. xen0morph
    30 Jun 2002
    Possibly the two batteries would charge at different rates and you'd end up with some kind of charge imbalance which would kill the batteries over a long period of time?
    No, I have no idea what I'm talking about. Too much vodka.
  7. :: Phat ::
    7 Jun 2002
    I think the reasoning behind it is something to do with the design of the battery, that two on the same line would eventually kill eachother when the car is left off.... Hence why a split charge system cuts the second battery off when the alternator isn't running.
  8. A13n0rma1
    A13n0rma1 Wannabe
    17 Jul 2003
  9. D B
    D B What's a Dremel?
    11 Apr 2004
    depends on what you want the other batt. to help with
    The above link is for using the other batt as an aux. batt, used for running things like radio, etc. so as not to drain the starting batt
    If you want to help the starting batt to start the vehicle , then hook both batts together , pos to pos/neg to neg , Parrallel . You can hook batterys together this way and they will not hurt each other , many diesels have this arrangement because of size constrants on how big a batt needed verses room for it.
    Yes , it will put more load on your alt, (ether way) but there are devices designed to limit current that are a good idea (say you drained way down that aux. batt, now your altenator is going to put out it's max. output for as long as it takes to charge back up ... not good for the life of the alt.)
    DB
  10. slater
    slater Mummy Says Im Special
    18 Apr 2003
    On some of the stock car engines i have built we connect 2 batteries in series to get 24v. That helps cold starting quite a bit :D
    (Not relly a good idea)
    slater..
  11. xen0morph
    30 Jun 2002
    On a car with an ECU that would wreak havoc with the electronics. Wouldn't do the ignition system much good even on an old car =P
  12. slater
    18 Apr 2003
    Yeh they didnt have an ECU or any ancillary (sp?) electrics. IIRC The ignition etc. is only connected too one battary so still get 12v but thes another battery that gives the starter 24v somehow (dont ask me i just build the engines :D )
    slater..
  13. naughty
    naughty What's a Dremel?
    17 Feb 2003
    you can easilly parallel two batteries which will be charged by one alternator as long as you use an isolater or even a solenoid which are both designed for that purpose - ask your local car audio installation specialist
  14. micb
    micb Minimodder
    4 Sep 2002
    The question has to be what are you trying to acheive?
    What do you want to run and why?
    Do you want more reserve power, longer lasting power or dry cycle rechargable power.
