Notebooks 2nd hard drive in a caddy
Discussion in 'Hardware' started by WTF_Shelley, 7 Sep 2013.
  1. WTF_Shelley
    WTF_Shelley The picture is wheeljack
    6 Apr 2005
    Im running out of room on my Toshiba p750-135 laptop, The 128gig M4 ssd is nearly full and i never use my cd-rom. So i little research i found a caddy that fits into the cdrom bay and takes a standard laptop hdd. Awesome the only problem is the bezel on the existing drive. I can take it off but will it fit on the caddy, are the bezel sockets universal or have i got to look for a certain type? has anyone done this?
    I havent ordered one yet and dont want to get the wrong thing
  2. meandmymouth
    meandmymouth Well-Known Member
    15 Sep 2009
    You could order one, see if it right and then send it back if it isn't. You are perfectly within your rights to do so.
  3. ferret141
    ferret141 Well-Known Member
    18 Oct 2010
    If you struggle to find one you could try Pabbos. Their search system is a bit hit and miss but I've got keyboard covers and HDD brackets for my laptop from there.
