2or more microphones
Discussion in 'Hardware' started by pranks7er, 2 Sep 2003.
  1. pranks7er
    pranks7er mange tout
    25 Dec 2002
    is ther any way i can run two or more mics on my pc
  2. yodasarmpit
    yodasarmpit Modder
    27 May 2002
  3. penski
    penski BodMod
    29 Aug 2002
    Are you wanting two independant mics or two into one port?
    If the latter then the connector that Yoda mentioned (obviously dependant on the type of mics - will work with cheap PC mics - will be a little more complicated with proper mics) will work.
    If the former then you'll need a decent soundcard with two inputs that are suitable for an unamped signal and software capable of recording more than one source at a time...
    *n
  4. pranks7er
    25 Dec 2002
    2 into one port
  5. penski
    penski BodMod
    29 Aug 2002
    You wanting two people to be able to sit side by side and use voicechat or something?
    *n
  6. pranks7er
    25 Dec 2002
    its 4 a voice chat so aperson in another room can listen but need 2 mics because one isnt picking up all sound
  7. penski
    penski BodMod
    29 Aug 2002
    Just use the 2>1 connector.
    You may have problems with interferance or feedback...
    *n
