Cooling 2rigs off 1 WC system
Discussion in 'Hardware' started by buchans, 7 Oct 2004.
  1. buchans
    buchans What's a Dremel?
    28 Jun 2004
    I want to run 2 rigs (2xCPU 1xGPU 2xNB) off a system with 1x120mm rad and a 1m p/a WACC res - still to test this out but would like some feedback to save wasting time...
    I think the res can cope with one system but I'm not sure if I need another 1x120mm rad in the second machine or if positioning the rad correctly could cool enough? IE cool the output from the 1st system before it goes into the the 2nd?
    I want to get a nice 3x120mm rad - almost sure that would do the trick - but thats a next payday purchase :sigh:
  2. daniel_owen_uk
    daniel_owen_uk What's a Dremel?
    1 Sep 2003
    Yeah wouldn't suggest using 1x120, 2x or 3x would be ok, make sure you have a good quality pump too.
  3. buchans
    28 Jun 2004
    got a Hydor Seltz L20 Pump - do I need another one?
  4. Risky
    Risky Modder
    10 Sep 2001
    I've though about this one before. One solution is to have two 'distibution' resevoirs, "hot" and "cold". The radiator loop would have a pump and rad and take from hot and empty to cold. The two pc loops would have not rad but pump from cold to hot. You then have a double overflow line so that if either res is too high, it drains to the other (the resevoirs are at the same height and the two lines are above one another, connected in a crossover so the higher level drains to the lower.
    EDIT: So that's two reservoirs with five ports each and three pumps :jawdrop:
    I'll do a diagram when I have somewher to upload but it seems elegant enough.
  5. buchans
    28 Jun 2004
    VERY elegant, I may try this :D
  6. fivecheebs
    fivecheebs Dont panic!
    19 Feb 2003
    Sounds cool, I can host it for you if you like..
  7. Risky
    Risky Modder
    10 Sep 2001
    I should have said, "when I'm somewhere I can upload it"! It will be later anyway I'm afraid.
  8. Risky
    Risky Modder
    10 Sep 2001
    Actually the drain arrows are probably misleading, but the imortant thing is that it could drain in either direction. You could do it with a single res with a divider, if you were making it up in plexi:
    This would be the approach I might one day use if I have a bigger place and wanted to cool a few PCs with maybe an outdoor radiator (to keep the fan noise away. Theres all sorts of scope for thermostatic control of pump speeds and radiator fans, and the whle arrangement is expandable for additional PCs.
    Of course this would also work in an external radbox with a pair of aquatubes....
  9. user0001
    user0001 What's a Dremel?
    8 Sep 2004
    Yes, dont be a water cooling freak and drop a benjamin for a simple radiator. Just check out heatercores for cars and find one that is big but not too big. Or instead of getting a bigger/second rad, you could make a huge cooling res to keep temps down :D
  10. Mace
    Mace Ohh, it stings.
    9 Dec 2003
    He's from scotland, not everyone knows what a benji is ;)
  11. buchans
    28 Jun 2004
    this is the case its going in, yes a heatercore would be cheaper but a 120x3 rad is just begging to be installed.. I think its important to make this thing esthetically pleasing
    this is my res, its more than enough to passivly cool one rig.... I just don't think it would be enough even with the rad to cool both (the second is a gaming rig with a 6800GT)
    and yes I know what a benji is :D
