2T for DDR2?
Discussion in 'Hardware' started by Pookeyhead, 6 Oct 2006.
  1. Pookeyhead
    30 Jan 2004
    Is it normal for DDR2 to run a 2T command rate? Just noticed the SPD timings for Dominator modules states 2T.
  2. Guest-16
    Guest-16 Guest
    Yup, I think that's JEDEC too.
  3. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    There's usually no option to set command rate on Intel boards, since Intel always runs 2T anywho. (Shocking there IS an option on this 775-dual VSTA board, but it appears to make performance worse)
    If you run AM2 you *should*, depending on the mobo be able to run 1T to ~ the DDR2 800 mark (400 fsb). This is heaviliy board and ram dependant though.
  4. Pookeyhead
    30 Jan 2004
    Just curious really.... It doesn't seem to hurt the benchmark figs. I just wondered if anyone had run fast DDR2 with 1T.
