hey all, im looking for 2x 22" monitors as the title suggests. max budget id say £250 for the pair so im looking at TN panels i only game really on the PC aside from the usual web browse and post on here etc. i actually have a samung 22" 2233BW which is a 1680x1050 panel and its done me fine for over 18 months so maybe buy another one although im looking at around £150 or so for it. just thinking of doing a cheeky upgrade on my res maybe as come xmas ill probly get a new GPU. currently running i7 920 @ 4Ghz 6GB DDR1600, 1TB F1 and a 1GB 4870. ooo must be vesa mount as im gunna using a dual monitor bracket for my low profile desk as good as i am choosing hardware monitors is somwhere where i rather lack so any suggestion much appreaciated
I don't have any monitor suggestions, but let me know if you find a decent dual monitor bracket as I've recently been looking at getting one for my 2 22" monitors.
http://www.amazon.co.uk/MDM05-Multi...4?ie=UTF8&s=electronics&qid=1281197560&sr=8-4 this is what ive been looking at
Well was thinking of upgrading my resolution and wondering about 1920x1080 22" ones any recommendations ? There is a lot of choice so not sure what to look at
This one is on PCPros A list. BenQ G2222HDL Two of them from Ebuyer would cost you £273 so a little over budget but might be your best option. Just sold a 2232BW as well.
To be honest, monitors around that price range are all much of a muchness really. They're all going to be TN panels with 2-5ms response time, so you'll have a good idea of how they'll perform. I'd say just pick the one you like the look of most, make sure it has DVI/HDMI, and be done with it. You're probably worrying over very small differences.
yeah maybe but i seem to remember reading an article once in custom PC with a monitor round up using a few TN panels and there was a big difference between quality even though they had very similar specs
just had a quick look at 2 of them are 254.82 inc del. where were you looking ? they look good no nonesense decent TN panel. i may have to invest. EDIT - **LOL Fail on my part a cheaper HDL version is also on there**
