Shouldn't be an issue, as long as you're not overclocking the GPU's with an i7 rig as a reference point you're probably going to looking at a draw of 630W (peak) from the PSU itself.
Their power connectors are: 8-pin = 150w 6-pin = 75w PCI-e slot = 75w Two cards can take 600w at load (and there's some reference to higher than that in Furmark...). The corsairs run a single big +12v rail, so that should be fine. The rest of your computer will be 150w or so. You'll make it - lucky you have a decent PSU!
