Cooling 2x Inline External Reservoirs
Discussion in 'Hardware' started by xperiment, 17 Sep 2005.
  1. xperiment
    xperiment What's a Dremel?
    17 Sep 2005
    I am looking to mount two of the above on the top of my case, just for looks, I understand there is no other benifit to doing it. Just wondering if anyone has done this and seen any problems as a result of it.
    I will be using 2x http://www.watercoolingshop.com/catalog/images/capeplex25.jpg simply placed along side each other with the output on no.1 connected directly to the input on no.2.
    If anyone can think of any problems this would cause, feedback would be much appriciated.
    :D
  2. Shadowed_fury
    Shadowed_fury Minimodder
    21 Nov 2003
    No problems with it, with a decent pump you'll be fine.
  3. Nexxo
    23 Oct 2001
    As long as the outlet of res 1 and the inlet of res 2 are below the water level, it should be OK. It has been done several times, btw.
  4. Breach
    Breach Modding in Exile
    20 Jun 2005
