Cooling 2x120 rad be good enough?
Discussion in 'Hardware' started by grritsshawn, 27 Feb 2010.
  1. grritsshawn
    grritsshawn I'm not insane I'm a modder
    20 Apr 2009
    Ok well I'm going to water cool my pc soon and i am gonna be water cooling my hard drive(i got the block for free) my cpu (3.8ghz core i5 750) and my 5850 at stock.
    Would a 2x120 rad be good enough or should i had an extra one?
  2. Picarro
    Picarro What's a Dremel?
    9 Jun 2009
    A single 2x120 might be on the small side. I think it would work much better with a 3x120.
  3. grritsshawn
    20 Apr 2009
    i dont have enough room for a 3x120
  4. Picarro
    9 Jun 2009
    Hm, then atleast remove the HDD water cooler. Unless you have a pump that kicks quite a punch it will just restrict flow. HDD's, in most cases, do not need cooling. You make sure to have some kind of airflow over it.
  5. grritsshawn
    20 Apr 2009
    it does 600 liters per hour
  6. grritsshawn
    20 Apr 2009
    well im off to work read this when i get back
  7. Volund
    Volund Am I supposed to care?
    16 Sep 2008
    you at least have room for a 120.1 and 140.2 in the PC-K60, that is what I'm planning with mine, 120 on back fan, and 140.2 on top with some modding to make it fit under the top bezel and over the mobo.
  8. grritsshawn
    20 Apr 2009
    i am using a nzxt whisper and i want to have all parts of water cooling inside
