2xGPU folding means CPU slowdown?
Discussion in 'bit-tech Folding Team' started by Synay, 19 Apr 2010.
  1. Synay
    Synay What's a Dremel?
    25 Oct 2009
    I recently slotted in another GTS 250 and prepare to fill in the third slot this week as well. Aside that CPU works are so hard to get, I noticed my Cpu's PPD dropped quite substancially:
    I didn't set anything up apart from running my CPU client with -smp 4 flag, disabled SLI and Physx on GPU's with aproppriate flags as well. Am I missing something or is that normal. Any help would be appreciated.
  2. Ph4ZeD
    Ph4ZeD What's a Dremel?
    22 Jul 2009
    My CPU always drops in PPD when I get my graphics cards folding, its normal.
  3. saspro
    saspro IT monkey
    23 Apr 2009
    Try to make sure the gpu's are using different cores to minimise the impact
  4. Synay
    25 Oct 2009
    Do you mean, like setting affinity in Task Manager? Say: one card to use CPU 0 and the other CPU 1?
  5. saspro
    saspro IT monkey
    23 Apr 2009
    I used to use priaffinity to auto set them as they have a habit of reverting back to random cores when they start a new WU
  6. Synay
    25 Oct 2009
    Thanks. I tried first manually in Task Manager. I will give it next hour or so to see if there's any difference.
    Logically then, when I add the third card, my CPU's PPD will drop even further?
  7. Ph4ZeD
    22 Jul 2009
    Pretty sure, yes. Of course this is off set by the gains from your graphics card.
  8. Synay
    25 Oct 2009
    You are right.
    The experiment with core locking gave a gain of about 100 PPD. Not much difference there. Thanks guys!
  9. leexgx
    leexgx CPC hang out zone (i Fix pcs i do )
    28 Jun 2006
    is that an A1 work unit your doing you can get 13k or more just from using the A3 work units (use an passkey and advmethods on) use HFM.net to monitor as well
  10. Synay
    25 Oct 2009
    I'll try after this one. If I can get a WU that is :)
    With HFM.net I have a bit of a problem.
    Code:
    Description:
      Stopped working
    Problem signature:
      Problem Event Name:	CLR20r3
      Problem Signature 01:	hfm.exe
      Problem Signature 02:	0.4.10.156
      Problem Signature 03:	4ba1712b
      Problem Signature 04:	Castle.MicroKernel
      Problem Signature 05:	1.0.3.0
      Problem Signature 06:	46f2e4dd
      Problem Signature 07:	1a
      Problem Signature 08:	e2
      Problem Signature 09:	WM0DLCLN0FFELNNYQUIWRCMEAUTRMMW2
      OS Version:	6.1.7600.2.0.0.768.3
      Locale ID:	2057
    Ignore the problem, sorted :)
  11. leexgx
    28 Jun 2006
    you get 4-5x more PPD and more work done with the A3 work units (4ghz should be around 14-16k)
  12. Synay
    25 Oct 2009
    That would be very nice. I just configed the client to advmethods but still have 8 hours to go with the A1, so in the meantime I'll head off to sleep and let the pc do it's work.
  13. dark_avenger
    dark_avenger Minimodder
    9 Jul 2008
    if i remember aren't 1920 pointers core A2's?
    Would recommend changing over to the A3 anyway as they run better.
    Just make sure to add the -advmethods to your config
  14. Synay
    25 Oct 2009
    Already done it. Configured it so I don't have to add a flag. Got a passkey and everything but sadly I see there's still shortage of A3's. Client is on 12th retry and nothing,
