Electronics 3.5mm power lead?
Discussion in 'Modding' started by bigsharn, 1 Aug 2008.
  1. bigsharn
    bigsharn Officially demotivated
    9 May 2008
    Hi all... I was having a think the other day (and I haven't had chance to get on to ask)... but those passive speakers you get are powered by something right? and they only have a 3.5mm jack in them... so does anyone know by chance how much oomph they put out? (I was thinking LEDs maybe)
    Thanks all
    Sharn
  2. SteveyG
    SteveyG Electromodder
    23 Nov 2002
    Passive speakers are exactly that - passive. So no power other than the amplifier output is present.
  3. bigsharn
    9 May 2008
    so... it depends on the outlet?
    thing is I work for a tourbus company, and my phone sometimes goes dead... we use 3.5mm jacks for the headphone ports, so (as well as the LEDs from the 3.5mm jack in the PC) I wanted to mod a nokia charger to work with the headphone outlets
  4. SteveyG
    23 Nov 2002
    Doesn't work like that I'm afraid. Back to the drawing board ;)
  5. lost_modder
    lost_modder What's a Dremel?
    5 Dec 2006
    yea those speakers are just like headphones. not a good power supply there.
  6. mattthegamer463
    26 Nov 2004
    Speakers also operate on AC I believe, so even if there was enough power there you would still need to design a AC->DC circuit to make the power usable.
  7. profqwerty
    profqwerty What's a Dremel?
    2 Jan 2006
    Hmm, presumably if you just connected an LED + resistor across a speaker terminal, it'd flash at the same frequency the speaker's going at, maybe even to the point of varying brightness with frequency!
  8. bigsharn
    9 May 2008
    *Idea officially stolen*
    :p in all seriousness I'll probably use it on Project AT-AT, thankles:thumb:
  9. cpemma
    cpemma Ecky thump
    27 Nov 2001
    It does, but a few points;
    • No flash at all until the voltage exceeds the LED forward voltage (though that makes it good for picking up the louder beat);
    • You'll need a diode in inverse parallel with the LED to limit reverse voltage
    • A 50W amplifier has around ±33V max at the speakers so apart from blowing LEDs you can get a shock
    Better way is to get the speaker voltage to trigger a transistor switch to the lighting, that only needs >0.7V.
  10. bigsharn
    9 May 2008
    Is there any chance I can make it only work with music and make it not pick up sound from games or the various Windows sounds?
    I'm just thinking for if I have a friend round and I play CS: Source and the LEDs flashing whenever I fire a round might get a tad annoying:p
    If not I'll just stick a manual switch in the circuit:)
    even better, could I just get a speaker, take it apart and attach LEDs to it... then play a frequency on the line out port (Having my speakers in a different port)... then it flashes to that frequency?
