Okay guys I need your wisdom to help choose a new CPU water block. The Pumps I'm using is the DDC1-Plus so its powerful enough for most. I will be cooling the following and all is 3/8": CPU x 1 GPU x 2 DD Aqua Drive x 1 3 X Black Ice GT 120 I am really considering the following but I'm open to suggestions: Swiftech Storm Rev 2 D-TEK MP-05 SP LE Apogee Given the number of rad's and blocks I'm a little concerned about the flow rate using the Storm but it probably not an issue. Thanks in advance
Thanks for the info Kayin. It's narrowed down then as I will remove the apogee. I might just buy a flow meter and both remaining blocks then do some testing. Cheers
I should imagine the Storm is a good block, i have a Storm 4 and its brilliant, cools my CPU well, and despite the loop goes to a 7800GTX, the 78 doesnt go above 35 Sam
