So msot of my watercooling equipment has 1/4" tubing (which isn't really that great...) and my new pump and block can do 3/8" (i.e. they came with the fittings as well), and thus I want to change to 3/8" fittings without upgrading ALL my stuff, any place to get some? I'm not looking for 1/4" to 3/8", the pump uses the exact same type of fittings as the radiator and reservoir, they're Thermaltake
I could be wrong, but your flow is limited by the thinnest point. So if any point remains 1/4", you might as well stick with that.
IMHO Thermaltake's H2O system is pure crap anyways, and switching over to 3/8" with their rad/waterblocks probably won't make much of a difference. In all sincerity you'd be better off with a quality DangerDen/Swiftech/EK-Waterblocks/Thermochill/D-tek H2O system
i agree with radodrill. Cept thermochill are almost impossible to find and super $$$. Looks as if a full upgrade might be in order...
I don't have that kind of money available to me, it's not by choice, it's by how much I have available to spend on, buying a new block and pump more or less used up my funds for misc items for this month and the next
Chances are that if you're using any Thermaltake parts in your setup (except for maybe a res), it's not going to make a whole lot of difference. Depends on what kind of radiator it is too - I know Tt rads used to be multi-pass 1/4" copper tubing (not sure if newer ones have changed); if that's the case, there's little point changing over the fittings since it's still a pinch point.
Great, thanks Ooh I see, just checked mine, it's a 10-pass system, and the tubes look very much 1/4" Well, I guess it looks like I'll be investing in a new radiator too then Thanks though I think I should be OK if I get one of those BlackIce pro dual-pass 120mm rads?
The Swiftech QuietPower rads have an advantage over the Black Ice GTS when using low-cfm fans. I like shopping at Petra's Tech Shop
Ah alright, so I can get the dual-pass BlacIce Pro (it's a bit cheaper, more money saved, the better) and it'll work just as well? I might be adding a northbridge cooler later on as well since the 680i northbridge likes getting very hot though I was thinking of doing like CPU > Rad#1 > NB > Rad#2 > Res > Pump > CPU Edit: Actually on that note, what would be a good northbirdge block to get and what to put on the southbridge since if I remove my northbridge cooler, I need to remove the southbridge one as well since they're heatpiped
