Cooling 3/8" Tubing - 1/2" Tubing
Discussion in 'Hardware' started by buglish, 20 May 2003.
  1. buglish
    buglish What's a Dremel?
    8 May 2002
    i have a component which needs 3/8" tubing, and the rest of my kit uses 1/2". what i wanted to ask is, is there any way i could bring the 3/8" into a 1/2" watercooling setup. would it be as so easy to buy a little 3/8" tubing, moisen it, then slide the 1/2" over it, seal it, or could this cause a problem with waterflow etc etc ?
    any help appreciated, ty :)
  2. Morphine
    Morphine weeee!
    23 Feb 2002
    they make reducers, I used them in my setup
  3. jetsetjimbo
    jetsetjimbo Up-up and away
    19 Feb 2003
    Wimbo - most o/c'ing stores sell them... what component has 3/8" fittings? Wouldn't be a res would it?
  4. buglish
    8 May 2002
    ah right, thought there might have been something like that around, cheers :thumb:
    BTW, the component is a PSU that is watercooled :)
  5. 8-BALL
    8-BALL Theory would dictate.....
    6 Nov 2001
    Where from?
    Pics, pics, pics!!!!!!!
    please.
    8-ball
  6. jetsetjimbo
    19 Feb 2003
    Yeah, give us some piccies :D
  7. buglish
    8 May 2002
    i actually bought it from Adam from these boards, i will be attempting this mod also from scratch, nothing like doing a good mod yourself hey :D
    i bought it a while back before i had the cash to actually start the watercooling
    will try and get a pic of it later on for you :)
  8. jetsetjimbo
    19 Feb 2003
    Did you buy the whole rig off him or did he end up selling it in bits?
  9. buglish
    8 May 2002
    i only bought the PSU as i have the rest of my watercooling bits and bobs now, Mmm :rock:
  10. Haddy
    Haddy World Domination
    22 Jan 2002
    Tygon 3/8s tubing will fit on 1/2 barbs...Not so sure about clearflex...
  11. jetsetjimbo
    19 Feb 2003
    Clearflex should go over 1/2" as well..... just dip the end of the tube in a cup of hot water before attempting it, it should go over fairly easily then....
    But I get the feeling you're using all 1/2" anyway and want to step it down to 3/8" ?
  12. buglish
    8 May 2002
    im actually wanting to run 1/2" all the way round, instead of the odd 3/8" which will end up being out of place :)
  13. Haddy
    22 Jan 2002
    Ask "Adam" if you can replace the barbs with some 1/2 ones...Should be possible....
