3 beeps then no shutdown??
Discussion in 'Hardware' started by couzo, 9 Jun 2002.
  1. couzo
    couzo What's a Dremel?
    26 Apr 2002
    I have a new computer that I have built with an MSI KT3 mobo a athlon xp1600, a geforce 2 mx, a maxtor harddrive and a liteon cd-rw. I have set up everything and it loads windows xp fine but when I shut down it seems to close everything the screen goes black but then everything stay on and three beeps sound pause sound pause and sound until I pull the power plug out?? I have all the latet drivers but as I don't have the computer connected to the internet I can't do a windows up date would this help or does anyone have any other ideas??
  2. jamiesurfs
    jamiesurfs Boom Boom, Cha Cha Cha!
    21 Oct 2001
    Have you tried backing up all your essentials and reinstalling your OS?
  3. ug_the_caveman
    ug_the_caveman What's a Dremel?
    31 Mar 2002
    Check your mobo manual for the definitions of the beeps. If that fails ring MSI...if not SCREAM!
    Ug :D
  4. felix the cat
    felix the cat Spaceman Spiff
    11 Jan 2002
    id try reinstalling windoze aswell...
  5. Behemoth
    Behemoth Timelord in training
    1 Nov 2001
    There's a patch for XP not shutting down properly, it's actually not a hardware fault, more a software fault. Odds are that if you re-install your O/S then you may still have this problem.
    Patch can be foud on Windows Update.
